Old 08-25-2003, 02:28 PM
mgaska84 mgaska84 is offline
help me with a tranny swap
Im taking out my b18 ls tranny and putting in a b16 tranny. What i need to know i\s exactly how to do it. Is there anyway you can give me the simplest steps to do it right and also what parts and tools i'll need to get the job done, thanks
Old 08-25-2003, 04:42 PM
DarkAccord600 DarkAccord600 is offline
Send a message via AIM to DarkAccord600
Put it in the same way you took out the ls tranny. Use the same tools and if you plan on puttin alot of horses in your engine it might be wise to change the clutch and flywheel for somethin a bit better than stock.
Old 08-25-2003, 05:00 PM
more help
i havenbt taken it out yet, thats why im asking...do i need any tools to take it out, or anything special? im taking out my ls and putting in a b16, it bolts right in, correct? and do i need to take the axels off?
Old 08-25-2003, 05:20 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
to remove the engine and tranny you will need to remove the axles, only special tool i can think of that you will need is the 32mm(i believe) axle nut socket, and maybe a fork tool to remove the ball joints.
they are both b-series motors so you wont need new mounts.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-25-2003, 05:33 PM
right on, is it very difficult to take out and put back in? or what? if possible could you maybe give me the steps or detail of how to do it? thanks
Old 08-26-2003, 01:11 AM
bambam2000 bambam2000 is offline
dude just go to c-speedracing.com
but if u r planning on doing it your self make sure you get a bucket and every bolt and nut u take out put it in there and REMEMBER THE WAY YOU TOOK THOSE BOLTS OUT because if not your fucked and also if its your first time count on having your car up there for at least 4 days from sun rise to sun set (depends how good u r with the mechanic shit )
good luck!!!!!!!!
96 cavalier tranny swap with a 94 sunbird gothmoglord Non-Performance 0 10-22-2009 10:30 PM
Need Help! Engine/Tranny Swapping The Dude '88 - '91 Civic | CRX | Wagon | Shuttlee 2 06-11-2004 08:43 AM
Please help with Tranny Model # imnotnotjoe Lumina 3 12-16-2003 09:52 AM
help with b16 swap need parts and help 92b16si Engineering/ Technical 1 12-08-2003 01:19 AM
Need help with tranny swap!! Miles B '71-'87 Civic | CRX 9 12-31-2001 12:07 PM
