Old 08-25-2003, 02:19 PM
sihondasracer's Avatar
sihondasracer sihondasracer is offline
Send a message via AIM to sihondasracer Send a message via MSN to sihondasracer
JDM B16A or USDM B18C1
i got a intesesting ?...i have to offers on my hands.a JDM b16A, or , a USDM B18C1.? help me decide?
i live for the feeling i get when i downshift and feel the motor scream up to 8000 rpm and pull on any unsuspecting victim with the fury that an old hatchback should never have.
Old 08-25-2003, 05:20 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
GSR.
They both have the same Hp, but the GSR has a little more torque, and makes it peak a shade sooner, so it is funner to drive around town.
Old 08-26-2003, 03:14 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Re: JDM B16A or USDM B18C1
Go with the USDM B18C1. Assuming the JDMB16A is gen 2 (92+) and not a 1t gen (88-91), the GSR has a little more HP 170 @7600 vs 168 @7800, if it's 1st gen JDMB16A (88-91) then its 170 @7600 vs 158 @7600. However, the GSR has more Peak torque, and it achived Peak torque at a much lower RPM (128 ft/lbs of torque @ 6200 RPM vs 116 ft/lbs @ 7300 RPM). Low-End Torque rules the streets, and the GSR motor hits a higher peak torque at a much lower RPM. It takes the B16A 1100 RPM's higher to achive it's peak torque, and its still 12 ft/lbs less. At the time when the GSR hits its peak torque at 6200rpm, the B16A has much,, much less torque. As for abilty to spool the motor high, the B16A's redline is at 8500, and the GSR at 8100. Basically, the GSR is a better base motor to start building on due to the far greater low-end torque, the higher peak torque output, and the greater displacment. Remember, there's no replacement for displacment. You get all the benfits above, plus tad tad more HP. Also, when it comes to Forced Induction, when a low C/R is best, the GSR also has a slightly lower C/R, 10:1 vs 10.4:1.
Old 08-27-2003, 02:09 AM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
Re: Re: JDM B16A or USDM B18C1
i agree with all of that except the last line, which is valid, but if you were running turbo you would most definitely replace your pistons to something lower than 10:1 cuz that is hellof high for turbo.. so if you were planning on going turbo and your finally deciding factor was because of the compression ratios you'd be replacing them anyway.
Old 08-27-2003, 02:40 AM
Re: Re: Re: JDM B16A or USDM B18C1
You don't have to change pistons/lower compression to boost a GSR, or any B series vtec for that matter, it's called tuning.
Old 08-27-2003, 03:25 AM
Honda God
If he was planning to run 20 psi, I would have to agree. However, at the 8psi he would most likely run, he'd be fine. Proper tuning can go a long way. A few people with guts mix high compression and turbo's. Not recommended unless you know serious shit about engines and tuning, but it's be done a few times, producing mad results. Most of the time and for most of us that's not possible or we dare not try it, and with good reason, high compression and boost is generally a shitty mix and recipe for disaster. I know I sure as hell am not mixing boost and a high c/r. But for the PSI he'd run on stock internals, he can get away with the stock internals and c/r. And the GSR's slightly lower C/R will be a little safer, in this regard, than the slightly higher B16A. You are correct, however, if he's going to run 15psi, for example, he probably going to want to put in lower c/r pistons.
JDM vs USDM b16a internals? same? gsr916 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 05-11-2005 02:24 AM
b16a --> b18c1 maxspeedhonda Engineering/ Technical 6 12-14-2003 02:02 PM
1st JDM B16 160hp other gens JDM B16a a2 a3 170hp s14arb25det '88 - '91 Civic | CRX | Wagon | Shuttlee 4 12-14-2003 01:12 AM
usdm b18c1 vs jdm b16a2 jameskersten Engineering/ Technical 18 08-24-2003 12:44 PM
JDM B16A 88-91 CRX Shop Manuel Also includes USDM & ZC vern0013 Engineering/ Technical 0 08-01-2002 11:35 AM
