Old 08-25-2003, 12:04 AM
snipez's Avatar
snipez snipez is offline
battery question
i have a new alternator, new battery,
what could be causing the in-dash voltmeter to be reading just above 8 volts? It varies as well, like down to 8, up to 13, back to 9, all over the board
I assume its the alternator cuz the battery is full, I just charged it for not even 5 minutes. But the alternator is 5 days old
Old 08-25-2003, 12:10 AM
loesch8102's Avatar
loesch8102 loesch8102 is offline
Send a message via AIM to loesch8102
Did you unplug the battery when you relaced the alternator? If not it probably spiked the voltage regulator and you'll need a new one.
Old 08-25-2003, 12:59 AM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
is ur belt tight enough? did u check ur connections on the alternator n see if u jus dident leave em loose?
Old 08-25-2003, 08:10 AM
snipez's Avatar
Brand new serpertine belt, but loose a loose connection is a possibility.
And yes the battery was unplugged during installation
Relocating battery question doug294 '88 - '91 Civic | CRX | Wagon | Shuttlee 6 09-19-2003 02:23 PM
battery question snipez Grand AM 0 08-25-2003 12:06 AM
Battery Question fatboyslim Remote Control Cars 9 06-02-2003 06:15 PM
Battery Questions nsohn 7 Series 2 10-10-2002 05:15 AM
Light & Battery question atomic-G Cosmetics 3 01-31-2002 06:07 PM
