Old 08-24-2003, 10:03 PM
chechin chechin is offline
Send a message via Yahoo to chechin
VTEC problem!!
Hey guys, I got a problem with my engine, the vtec is not engaging (I always notice by the way it sounds), I checked at the oil level and it's ok
my engine is a B16A and it was fine until today, could that be possible that the vtec solenoid is damaged or something? what do you guys think that could be?
Old 08-25-2003, 10:43 AM
94civic's Avatar
94civic 94civic is offline
try cleaning out the solenoid. if that doesn't work try switching the solenoid out with a good one and see if that works. is you check engine light on? if so pull the codes and see what it says.
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 08-25-2003, 04:06 PM
Re: VTEC problem!!
Thanks, the check engine light is on but How can I get the codes?, my car is OBD2.
Old 08-25-2003, 04:28 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Re: VTEC problem!!
You need a reader for OBD II. If your car is a 99-00 Si, it is OBD IIb. You can buy the scanner on line, or goto Honda.
Old 08-28-2003, 01:41 AM
S1 Type-R's Avatar
S1 Type-R S1 Type-R is offline
Send a message via AIM to S1 Type-R
Have you tried to reset the computer???
Ive had my check engine light go on a few times due to me messing with the plugs....all I do is unplug the battery for a few mins and resets the ECU......If you do this and continues then go ahead an purchase the needed equipment but my suggestion to you is try reseting it first.
2001 ITR
WWW.SQUADONE.NET
Old 08-28-2003, 06:57 PM
dirty91crx's Avatar
dirty91crx dirty91crx is offline
Send a message via AIM to dirty91crx
its also possible that the vss has gone out....
d15b vtec problem & idle problem DrunkenTiger84 Engineering/ Technical 0 12-06-2003 11:18 PM
Vtec Problem FRNKNSTN-DA Integra 0 10-07-2002 06:41 PM
D16Z Vtec Problems... Need help.. JohnnyFiero '88 - '91 Civic | CRX | Wagon | Shuttlee 3 06-01-2002 03:49 PM
Integra VTEC problem.. pls pls help hangcool Integra 7 06-01-2002 03:31 PM
VTEC Problem LuDiCrAzE Engineering/ Technical 7 02-15-2002 04:21 AM
