Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-24-2003, 10:29 AM
Mitch92Blazer Mitch92Blazer is offline
Question "Service Engine Soon" light
My "service engine soon" light has been on for a while now, with the car having no apparant problems. I don't want to bring it to the dealer and spend the $ for nothing;
Any ideas as to why this is on?
The only thing that I noticed is the rubber air intake tube that connects the air filter box to the motor is badly ripped by the clamp, thus an air leak...
Can that be it?
Old 08-24-2003, 11:58 AM
BullShifter's Avatar
Reset the ECU then see if the light returns. If it does a scanner is your only answer to find out what code it is.
Old 08-24-2003, 01:25 PM
94blklighting 94blklighting is offline
ok to turn it off. there is a green button below the dash on the right side
if you get on your back you can see this button right above the gas pedal.
Old 08-25-2003, 11:20 AM
Spectre927's Avatar
Spectre927 Spectre927 is offline
Send a message via AIM to Spectre927
I had that problem once, and I called my local honda dealer. They said it probably meant that when I had the oil changed they forgot to reset it. I reset it myself and the light hasn't come on since. This was like 8 months ago.
Old 08-25-2003, 12:22 PM
The check engine light has nothing to do with an oil change on Honda's, maybe the Maint. Req'd Light - 2 different things.
Maint. Req'd - Reminder
Check Engine Light(MIL) - Warning light
Old 08-25-2003, 10:27 PM
Thanks, guys-
But how do you reset the ECU?
Old 08-25-2003, 10:50 PM
Disconnect the negative battery for 15 seconds, or depending on the car remove a fuse from the main fuse panel also works.
95 "Service Engine Soon" light RaiderRobert C/K 1 12-10-2003 12:49 PM
No "service Engine Soon" Light BOWTIE S-10 1 12-13-2002 01:54 PM
98 SE "Service Engine Soon" light on cse98se Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 07-21-2002 10:31 AM
"service engine soon" light Pole Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 07-19-2001 03:08 AM
