Old 08-23-2003, 10:06 PM
Honor Honor is offline
Send a message via AIM to Honor
Unhappy Hot brake problem
I have a 99 Voyager, and replaced the front rotors and brake pads. Now, the rotors and wheels get extremely hot. The brakes do not squeal, or grind, so if it's grabbing it is very lightly. The wheels never got this hot before, so I'm at a loss. The wheels get hotenough to boil water, so I imagine that everything else is even worse. This heat comes about after just short distances of a few miles, any ideas of what to look for or try? The brakes work, the ABS keeps things from locking under heavy braking, so , like I said, I'm at a loss of what to check. Thanks for any help that's out there.
Old 10-09-2003, 10:30 PM
junior mint junior mint is offline
Re: Hot brake problem
don't know if you still have this problem but I had the same thing happen and the caliper actually caught on fire.On your brake flex hoses there is a mounting bracket half way down the hose that connects to the strut tower,the crimp on this bracket might be to tight and causes the line to close not allowing the brake fluid to return back to the master fast enough. Take off the flex hoses and try to blow air through them.
Old 10-10-2003, 09:08 AM
The problem solved itself. It seems the combination of new pads and a new rotor made things just 1mm or 2mm too thick, so the pads rubbed non stop. It stopped after a couple more days by itself.
Thanks,
Honor
89 ford bronco 2 brake problem bigd428 Bronco 0 09-13-2010 09:14 PM
Braking Problems frehleycomet Tracker 2 03-29-2009 10:46 AM
hot brakes slim101692 Engineering/ Technical 5 01-09-2007 11:33 AM
2001 G Caravan hot brakes Albertst Caravan | Voyager 2 03-23-2006 01:12 PM
87 Accord with hot brakes gyronaut '88 - '91 Civic | CRX | Wagon | Shuttlee 0 07-06-2003 01:59 PM
