Old 01-03-2007, 03:53 PM
slim101692 slim101692 is offline
hot brakes
1990 geo prizm changed brake pads and now it smells like the brakes are HOT did i do something wrong? the brakes work great please help me asap
Old 01-03-2007, 05:39 PM
Gearhead202 Gearhead202 is offline
Re: hot brakes
by hot u mean temperature wise.
if they are excessively hot try jacking up the car and put the vehicle in neutral be sure the car will not roll first then give the wheels that seem to be hot a spin they should spin if they move but a great amount of force necassary then there may be a problem with your slides.
if that is the problem remove the caliper again and check them if they are rusty or rly rough clean them on a wire wheel and re lubricate them that should work.
Old 01-03-2007, 07:55 PM
Re: hot brakes
temp wise and i will try that thank u very much
Old 01-04-2007, 10:26 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: hot brakes
Did you bed them properly?
Old 01-06-2007, 07:52 PM
GreyGoose006 GreyGoose006 is offline
Re: hot brakes
i'm assuming that they are the correct pads and are in correctly...
they could be dragging, which would cause a lot of heat. like driving with the parking brake slightly on or your foot on the brake.
p.s.
silentchamber, where is your wierd sig picture?
and the avatar?
-edit
ooh, banned.
Old 01-09-2007, 11:33 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: hot brakes
You might get a smell for a day or so when they're new, but that should go away. You probably have a sticky caliper, especially if you pushed the piston back to get the new pads in. If one wheel seems to be hot to the touch after you park it, you found the side with the dragging caliper.
