Old 08-22-2003, 12:56 PM
hybridnorthern hybridnorthern is offline
shifter rattle
When I accelerate my shifter shakes and makes a rattling noise. At cruising speed it doesnt, just acceleration. (Its not very loud, just very annoying ) Well, I ordered some Energy Suspension polyurethane replacement bushings and am hoping that will take care of it.
My question is......Has anyone ever had this problem? If so, how did you fix it?
Old 08-22-2003, 01:13 PM
GTA's Avatar
GTA GTA is offline
Whee..
short throw shifter? if so, the linkage is touchign the exhaust cause it to shake. Mine does it in 5th gear and a lil in 3rd and 4th. The way to fix it is to modify (bend) the exahust hangers a lil bit to get the exhaust to hang a lil lower.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 08-22-2003, 01:19 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Had the same problem with mine, and when I installed the short-throw shifter and urethane bushings, it went away for the most part...
Old 08-22-2003, 01:23 PM
its not a short shifter.... if that makes any difference
Old 08-22-2003, 02:22 PM
ci5ic's Avatar
Re: shifter rattle
Nah... doesn't matter. If you install the bushings, it should clear up the rattle for you.
Old 08-22-2003, 02:39 PM
thanks guys!
Old 08-22-2003, 11:22 PM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
mine makes a noise only at high rpms like 6000 and any higher any one know why its doing that???? i havent messed with it yet because ill be taking it out for my swap anyways
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 08-23-2003, 03:10 AM
ian16v ian16v is offline
fine did the same..., must be a common thing! once i fitted my short shifter it was spot on. me thinks it was the bushes in the shifter
1995 Toyota Starlet GT Turbo Advance & 1991 civic b16a1 project/track car
http://www.boomspeed.com/civic16v
Why does my driver side door still rattle over bumps? jberenyi Suburban 0 03-12-2009 08:52 AM
94 ford f150 shifter temperingloser F Series 1 02-28-2009 12:27 PM
shifter knob? redka88 F Series 0 02-22-2009 01:03 PM
Gear Shifter Rattling Mycollie Windstar 3 02-15-2008 09:08 AM
my shifter rattles. bnyce2u Integra 10 07-28-2004 10:11 AM
