Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-20-2003, 10:19 PM
lgrzybek lgrzybek is offline
Angry 3000GT - Burning Oil
'93 3000GT with 90,000 miles, was burning a little oil until the car was left running overnight by my teenage daughter. Car began to really smoke, people driving behind can't see the car, just a huge cloud of smoke.
Did a compression test, with 150psi range readings, so I decided to rebuild the heads: lapped valves, cleaned up all the burnt oil, installed new valve guide seals, etc.....
Turned the car on and after it warmed up, no change to the oil smoke !
Any ideas on how I can troubleshoot the real problem, before plunging into tearing the engine apart again and losing more knuckle skin while removing the belts and timing belt covers ?
Old 08-21-2003, 10:42 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Sorry - I don't have anything to offer beyond some of the things you've already done.
Post your question on www.3si.org in the technical section and you might have one of the real pros on these cars give you some good information.
Resistance Is Futile (If < 1ohm)
Old 08-21-2003, 10:15 PM
Thanks, will sign on to 3si and see what info I get back.
Old 08-22-2003, 07:38 AM
iceguy2003 iceguy2003 is offline
Send a message via MSN to iceguy2003
Check the valve guides. The car could have possibly gotten hot and burned them up? Either way, that's one of the main problems with our cars...the valve guides go bad. Well...when I say check the valve guides, of course that isn't easy...but, I recommend replacing them.
1991 Dodge Stealth R/T 3.0 DOHC 24 Valve
Bored .060" over, 11:1 Pistons, ACT 2600 Stage II Clutch, Test Pipe, Flowmaster Exhaust, K&N Filtercharger, Chrome Polo Wheels wrapped with Yokohama AVS ES-100's, 2 Rockford Fosgate Amps, 2 Bazooka Subs, Shaved Door Handles, Viper Alarm System
http://images.cardomain.com/installs/246000-246999/246180_2_full.jpg
If anyone knows how to post a pic, tell me.
Old 08-22-2003, 02:54 PM
Re: 3000GT - Burning Oil
Thanks, valve guides looked good when I replaced the valve guide seals. Valves were sliding smoothly without any wobble or play on the valve stems. I suspect the oil rings, but the compression was good. Don't know if bad oil rings would show up on a compression test.
Old 11-11-2003, 12:02 AM
spriggan0072 spriggan0072 is offline
Send a message via AIM to spriggan0072 Send a message via MSN to spriggan0072 Send a message via Yahoo to spriggan0072
same prob
hey man,
i just got a `94 3000gt a week or so ago. the oil pressure and temp fluctuates when stop and idle for a while. my coolant is also leaking i think, it went low in like less than a week after i changed all the fluids. a friend told me i should replace my heads and hope that my oil pump hadn't gone bad, i'm still confused so i don't know what to do. i know this was back in aug, so maybe you found the problem....let me know if you did, thanks
-Roman
PS,
email me at [email protected]
Old 11-16-2003, 03:21 AM
98MitsuTurbo's Avatar
98MitsuTurbo 98MitsuTurbo is offline
Send a message via MSN to 98MitsuTurbo
Bad oil rings would actualy bring up the compression because the oil seals the piston to the cylinder wall. It sounds like the oil ring on the piston may be severly damaged. This seems to be the only possible problem because you rebuilt the heads. Other than that i couldent tell you.
Tim
**1998 Mitsubishi 3000GT VR4**
Old 10-04-2004, 04:24 PM
q2418130103p q2418130103p is offline
There is a good chance you need to rebuild your turbos.
If the car smokes more after its idle it could mean that oil has built up in the intakes.
This is the exact same problem my friend had and it was solved by a turbo rebuild kit, which is basicly just some new seals.
Old 10-05-2004, 12:35 PM
Igovert500's Avatar
blue + red light magnet
Welcome to AF, but please do not bring back year-old threads.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-05-2004, 01:49 PM
sorry bout that, found this topic from a google search
Old 10-05-2004, 01:56 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
thats where alot of people find it, I did. Lets not post here anymore and let it die/get locked.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
1995 3000GT Turbo manual transmission problem rene8603 3000GT/Stealth 8 10-08-2009 03:49 PM
Burning oil at idle bhw33191 Caprice 20 09-13-2009 01:43 PM
smoking from the oil filler cap, dipstick and exhaust jimgbgt MGB 2 07-24-2009 04:26 AM
3000gt burning oil. PLEASE HELP!! azndragon916boy 3000GT/Stealth 10 02-28-2006 05:47 PM
Burning oil after switching to synthetic oil RedRacerCivic '88 - '91 Civic | CRX | Wagon | Shuttlee 7 01-20-2003 07:50 PM
Closed Thread
