Go Back   Automotive Forums Car Chat > Saturn > LS/LW
Old 08-20-2003, 09:12 PM
swzine swzine is offline
Send a message via AIM to swzine Send a message via Yahoo to swzine
Question 2003 Saturn L200 Remote Keyless Entry Programming
Does anyone know how to program an RKE transmitter for the 2003 Saturn L200? I tried the 96-99 SL2 instructions just to see if it works and it did not. Anyone know how to do this?
Old 08-21-2003, 12:10 PM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Re: 2003 Saturn L200 Remote Keyless Entry Programming
You need to take this one to the dealer as it requires a scan tool.
Transmitter Programming
Important
Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly.
Programming RKE Transmitters
Important
All key fobs must be programmed each time any one fob is programmed.
The scan tool must stay connected until all of the transmitters are programmed.
Install a scan tool.
Turn ON the ignition with the engine OFF.
Select Remote Function Actuation.
Select Special Functions.
Select Program Key Fobs.
Select the number of key fobs to be programmed.
Press and hold the LOCK and the UNLOCK buttons simultaneously on the first transmitter for approximately 15 seconds. The Power Locks should cycle to confirm programming of the first fob is complete.
If you are programming more than one transmitter, repeat the previous step to program up to four transmitters.
Remove the scan tool.
Exit the vehicle. Attempt to lock/unlock the doors to verify the programming.
Operate the transmitter functions in order to verify correct system operation.
Moving to Saturn Forum
Old 07-23-2012, 11:15 AM
wraith05 wraith05 is offline
Is the programming for the FOB of a 2003 l300 the same?
2001 Saturn L200 fuel gauge below E, DTC U1000 motorzonesuzuki LS/LW 2 08-14-2009 08:35 AM
2003 Saturn L200 christineparra General Discussion 0 01-24-2008 01:43 PM
Saturn L200 mass airflow sensor?? eborn General Discussion 4 10-12-2006 02:02 PM
saturn L200/L300 are based on what opel? badassgremlin General Discussion 5 11-04-2003 10:31 AM
Hand-drawn 2003 Saturn VUE LTD Graphic Manipulation 11 05-20-2003 03:26 PM
