Old 08-20-2003, 07:36 PM
loismustdie loismustdie is offline
blowing amp channels
i read about this guy who was blowing out all of his amp channels, and i wanted to know if operating the amps at thier maximum power output would blow out the channels.
if it helps im planning on hooking one 1000 watt 2-channel amp up to 2 500 watt rms subs. and running 500 watts, which is the amps max output, to each subwoofer. if this sounds like trouble to anyone or if anyone has any tips please post them.
thanks i appreciate it
Old 08-21-2003, 08:37 AM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: blowing amp channels
Depends on the type of amp
Old 08-21-2003, 03:01 PM
its a legacy 1000 watt 2 channel amp. and the 2 channels max out at 500
Old 08-21-2003, 03:08 PM
Haibane's Avatar
how long have you had it and what are you pushing speaker wise?
Old 08-21-2003, 07:44 PM
i have two 500 watt rms legacy subs, they were pretty cheap and i haven't had them very long
Old 08-21-2003, 08:09 PM
Haibane's Avatar
i'd check the fuses first, if not that, undo the screws and see if the sub is screwed up, they can't handle squat of any power
Old 08-22-2003, 03:36 PM
so operating the amps at max power all the time won't hurt them?
Old 08-22-2003, 05:45 PM
Haibane's Avatar
ONLY ON PIECE OF SHIT AMPS
Besides legacy has a good warranty, USE it
Old 08-24-2003, 02:32 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
all amps run at max power all the time (as long as they're on)
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 08-24-2003, 03:28 PM
so why do they have rms and max power options
Old 08-24-2003, 04:27 PM
Haibane's Avatar
cause turning up the headunit sends more power to the speakers/subs and therefore they tell you how much it can constantly push versus how much it can spike at if you are lucky
Old 08-24-2003, 07:06 PM
sr20de4evr's Avatar
Im sorry I worded that wrong, amps always push at their full output all the time which averages out to the rated rms power. The "max power" or "peak power" is nothing more than a way for advertisers to say it puts out more power. In reality that's just where the power spikes like haibane said. When looking at amps, don't look at the peak power, it's useless. The actual power that the amp puts out is the rms power.
'01 Black Sentra SE
'05 Silver WRX STi
Old 08-27-2003, 06:12 PM
in that case if i wire a 500 watt rms amp to one of my subs will it hit alot harder.
if u have any suggestions, please give me a link to a good amp.
Old 08-27-2003, 06:21 PM
and if so how can i tell if the amp is goin on rms or max.
if i figure right it would make sense just to match the max of the amp with the max of the sub, and then the both rms ratings should line up.
if that is not the case then please tell me otherwise
Stock Radio for installing Subs/Amp? robkule422 Car Audio 8 02-01-2011 07:29 PM
AMP/Speaker wiring in cooler boom box Chupacabra111 Car Audio 6 12-20-2010 05:29 PM
2000 IG ignition fuse blowing...Please help!!! stanley24538 Metro 5 04-24-2010 09:18 PM
3 channels into a 2 channel amp mother_russia Car Audio 16 03-15-2005 09:59 PM
engine noise thru speakers after blowing amp fuse Tracit Car Audio 3 08-08-2004 10:43 PM
