Go Back   Automotive Forums Car Chat > Plymouth > Horizon
Old 08-20-2003, 04:26 PM
Neil O Neil O is offline
87 Horizon charging prob
My boy has an 87 Horizon that has an intemittant charging problem - sometimes it does - sometimes it don't. Of course when he took it to the mechanic, it don't. Someone mentioned maybe the voltage regulator but he has no idea where it is hidden on these cars (He has a parts Omni but can't find it on either) Is it in the alternator or cleverly hidden somewhere else? Any body else have charging problems? (He has changed the brushes in the alternator already)
Thanks
Neil O
Old 08-20-2003, 09:17 PM
pcv pcv is offline
The regulator for the alternator is incorporated into the computor which is next to the battery. Check the computor terminals first.
NOTHING LIKE AN OLD CAR.
Old 08-21-2003, 12:56 AM
horizonking69 horizonking69 is offline
im just guessing but if u have new brushes for the alternator and still have problems chargiung then maybe u need a new battery i have a 87 horizon
Old 08-27-2003, 09:38 PM
Honor Honor is offline
Send a message via AIM to Honor
I would tend to agree that it is a bad battery, one that is not quite shot, but getting there. If you have a volt meter, set it for DC, and with the car off, see if you have 12 volts. If not, it should drop by sets of 2, 2 volts less for every bad cell. If you do have 12 volts, turn on the car, and watch your meter. Once the car starts, you should start showing about 14 volts if it is charging. If you have 12 off and 14 on, then it is something else...like a loose wire, an intermittent short, or something along those lines.
Honor
......use to drive a horizon/omni, have moved up to mini-vans
Old 03-22-2004, 07:00 AM
sojourner sojourner is offline
I thought the voltage regulator wasn't located by the battery, those relays are the starter relay and the fuel pump relay, the voltage regulator should be to the left of the air cleaner, hidden back behind all the vaccum hoses, If the alternator tests fine, the battery tests fine, chances are the voltage regulator is fried, not too expensive, easy to change once you find it, think is located behind all those vaccum lines to the carb, etc...
Old 08-11-2004, 03:21 PM
TrailLeadr's Avatar
TrailLeadr TrailLeadr is offline
Re: 87 Horizon charging prob
Most Horizons had their voltage regulators located on the firewall. It's a chrome plated box about the size of a deck of playing cards. It will have a three pin triangular plug. The regulator itself is not usually expensive at all.
93 Suburban 2500
203,000 miles on engine still running like a champ!
Tranny rebuilt at 197,000
My Daughter calls it the bus, and sits in the
third row seat praying for potholes and speedbumps!
Just Horsin' Around Equine Services
http://www.JHA-Trans.com
Charging probs with 2000 4WD ganjarome Sierra 0 01-11-2011 06:15 PM
1999 Sierra 1500 V6 Charging Probs lopockets Sierra 4 10-22-2008 05:34 PM
87' Dakota Charging Probs IronCowboy Dakota 4 02-20-2008 12:48 PM
93 Lesabre C Charging Prob. KMSwigart LeSabre 10 01-17-2007 08:19 AM
91 Grand Voyager 3.3L code 41 Charging prob madrieger Caravan | Voyager 6 01-24-2006 04:21 PM
