Old 08-20-2003, 01:54 PM
toronto pimp toronto pimp is offline
front upper arms
My upper ball joints are dead on both sides and i was wondering if there are any aftermarket upper arms for 4G hatch's? I really dont feel like paying $129cdn/each to the dealer.
- Eibach Sportline Springs
- KYB GR2 Gas Shocks
- The usual clear lenses/hyperwhite bulb
Next: Front/Rear lower tie and upper strut bars
Old 08-20-2003, 02:23 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
yeah.. they're definitely not cheap...but at least they're easy to do.. .not sure of any aftermarket parts.. I'd stick with honda if I were you.. does www.hondaautomotiveparts.com have em any cheaper?
SOLD!
Old 08-20-2003, 09:11 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Yeah, they are about 94.00 each plus shipping. I got mine at the local carquest for about 99.00 each plus tax.
Old 08-20-2003, 11:55 PM
spongerlbc's Avatar
spongerlbc spongerlbc is offline
Send a message via AIM to spongerlbc
Specialty Products makes an adjustable upper ball joint for our cars to correct for camber. I believe a set was around $150 or so. My upper ball joints are dead and I need to replace them and fix my camber so I figured I was gonna get a set of these. I think there was a site off groupbuycenter.com that sold them.
DOHC ZC 89 DX HATCH
Old 08-21-2003, 12:15 AM
Axe91CVC Axe91CVC is offline
dude if only the front upper control arms from the 5th gen hatch would fit the 4th gen ......then you could get some SKUNK2 adjustable camber cntrl arms .......Bcuz SKunk2 only made them for 5th gen and up......
i still dont know if they even fit ....soo dont quote me.....but if they do ....you'd have to do some cutting to the fender well......i just posted almost the same damn thing check it out.......skunk2 front Upr Ctrl Arm "Question".........i had the same thing happen i wanted to correct camber while replacing the upper balljoint
Old 08-21-2003, 07:43 AM
marked001's Avatar
Moderadur
Re: front upper arms
..if you can, post up a picture of these... I had a set of adjustable upper arms that were the biggest pieces of crap ever.. nevermind the fact that the simply didnt fit... even with an extensive amount of trimming... but the quality was horrible and the ball joints busted their welds..
SOLD!
Old 08-21-2003, 05:05 PM
marked ....do you have a picture of the "CRAP" adjustable arms?
i think i've seen this kit made by a company called sprint.....but everytime i've called a website that had it advertised they were telling me that the item has been discontinued........so ...still looking for an adjustable front arm ( for camber correction )
Old 08-22-2003, 10:12 AM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
If you want better camber without actually buying a camber kit, upgrade your upper control arms to the ones from the 90-93 Integra.
I have them on my Si, and when it sits on 15's with about 1/2" of wheel space, the camber is about -1 degree...Thats pretty much perfect for a good balance between performance and even tire wear. Plus its Oem honda, so you cant go wrong there. My mechanic also has this done to his Si with the same results. Good upgrade....worth looking into.
There's nary an animal alive that can outrun a greased Scotsman!
Old 08-22-2003, 10:37 AM
will they fit on an 89dx hatch?
Old 08-22-2003, 11:15 AM
marked001's Avatar
Moderadur
crappy picture...but this is them I believe... its chassis tech crap from AIM...so I shoulda known.. there are ball joints that slide in those grooves.... do NOT buy these... the control arms do not fit in the wheel wells properly and hit the top of the wheel well... the will not fit, even with extensive trimming
SOLD!
Old 08-22-2003, 04:24 PM
In reply to :
well i dont think the integra arms will work ...i have adjustable lowering springs all around ........so i'm needing something i can dial in the camber with ........i think with the integra control arms and the lowering spring would just add more to the negative camber right?
Old 08-22-2003, 10:59 PM
i have
skunk2 coilovers
tokico blues
Ex front brakes (big brakes)
I did the integra control arms before i did my big brakes, and the skunk2's have been on for about 2 years. So, I have no problems with having them fit. They should fit any 88-91 civic/crx, seeing how the 2g integra is based on the civic platform.
Like I said...with 14's and 15's, the car rides perfect and the camber is optimal. There's no need to "dial-in" because its perfect the way it is.
This is a cheap and effective alternative to spending $150+ on new control arms or some crap ones that will move on you.
92 Accord front upper control arm ball joint boot starynight Accord/TSX/Accord Hybrid 1 10-02-2006 09:42 PM
Replacing front upper control arms, is it easy? kdevine How-To's and Walk-Through's 2 06-30-2005 02:35 PM
Selling Front Upper Control Arms for Nissan Skyline GT-R 33, 34 gurmel General Discussion 2 02-28-2005 02:50 PM
Right front upper control arm. Santas90Si '88 - '91 Civic | CRX | Wagon | Shuttlee 1 09-24-2003 02:32 PM
Front Upper Arms EF9JDM '88 - '91 Civic | CRX | Wagon | Shuttlee 2 06-25-2002 08:09 AM
