Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-19-2003, 10:40 PM
censlow censlow is offline
Send a message via AIM to censlow Send a message via Yahoo to censlow
93 cutlass 3.1 odd idle problems
For the past month I have been having a come and go high idle problem. No real pattern . Just decides it wants to high idle. Sometimes when I start it after a 2 mile drive sometime when I put it in park after a 15 mile ride. Goes away after a few days sometimes. But it always comes back. Start high idle at like 1200 and goes steady to about 2k. Drive Idle at stop 800-1k. I noticed when it down shifts when it hits 1k during a downshift it will spike to 1200 and just before it stops in motion it will spike 1200 again. Otherwise drives fine. Any tips or clues would be a great help. Thanks.
Old 09-19-2003, 10:51 AM
tystik tystik is offline
I had the same problem with my 94 3.1. It turned out to be the IAC. Check the resistance between the pins on the IAC motor. A-B & C-D should be 20-40 ohms. When I replaced mine I had to drive around for a while to get the ECM to learn it's new idle. You might want to clean out the trottle body while your at it.
1995 cutlass supreme water pump 3.1 moemo Cutlass Series 1 05-02-2010 08:55 AM
96 olds cutlass 3.1 fan relay AK47 SRH420 Cutlass Series 1 04-16-2009 09:33 PM
92 Olds 3.1 Intermittent Idle Problem spfld03 Cutlass Series 3 06-23-2008 03:18 PM
'93 olds cutlass supreme 3.1 with idle problems themindbender Cutlass Series 1 01-05-2008 05:43 PM
3.1 Liter Idle Problem Harold56 Century 1 07-10-2007 07:04 PM
