Old 08-19-2003, 09:44 PM
fklimek fklimek is offline
Question Transmission Oil Pan 2001 Silverado
I have a shift cable running under the bolts that holds the transmission pan. Can I drop the pan without removing the shift cable?
Old 08-20-2003, 04:51 AM
mjrodney mjrodney is offline
Proud AF Supporter
I recall reading one post where someone had bent the bracket out of the way temporarily, but I doubt if that is recommended.
The service manuals tell you to remove the two bolts that hold the bracket on. These bolts on the 2001 may have Torx heads, but I do not know the size off hand. A set of Torx head sockets should do the trick.
Old 08-21-2003, 04:41 AM
Dihappy Dihappy is offline
Send a message via AIM to Dihappy
If i remember correctly i just swung mine out the way after removing one screw.
Remember the pan doesnt come off, i mean the y pipe wont allow you to remove it completely.
Oil Pan Gasket? ken_man_1 F Series 8 12-03-2010 07:30 AM
2001 Accent Transmission Oil Plug location peterf99 Accent | Verna 5 06-03-2009 01:57 PM
Mustang Transmission part 2001 lawg8r Mustang Problem Diagnosis 1 04-13-2009 04:24 PM
Oil pan/transmission pan gasket leaks-92 Lumina delicatedelinquent Lumina 0 03-22-2006 04:25 PM
88 LeBaron Transmission Oil Pan Mike_EX Lebaron 2 09-07-2005 11:10 PM
