Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 07-18-2005, 04:34 PM
Mike_EX Mike_EX is offline
88 LeBaron Transmission Oil Pan
1988 LeBaron is leaking transmission fluid badly out the pan.
Is there a Drain Plug for the transmission fluid like there is for the oil pan? I seem to remember that if the transmission pan is taken off a car
all the fluid falls out at once....not good in the driveway.
If there is a plug, where shuld I look for it? Thanks very much.
Old 07-20-2005, 11:03 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 88 LeBaron Transmission Oil Pan
sorry, there is no plug, if you want to drain the oil, you've got to take the pan off. Best thing to do, get a lot of old newspapers and a big container, like a container for holding coolant, and let it all drain from there.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 09-07-2005, 11:10 PM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
well, the best thing that i have found was to loosen all of the bolts just a little bit and then loosen one corner of the backside of the tranny pan and tap it with a soft blow hammer and then the fluid should come right out slowly, just make sure that you put the same amount back in and that you put the correct mopar fluid in it, i use the fluid, and then some lubegard atf protectant.
