Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 08-14-2003, 02:00 PM
Steve J. Steve J. is offline
80 Olds driveability problem
I have an 80 Delta 88 v6 that runs fine except it has no guts. Gets good mileage, idles & runs smooth, passes Calif smog. Has so little power it's dangerous to pass another car or merge on to the freeway. At WOT just before it shifts up it gives a _little_ surge of power, so I suspect it is ignition advance connected. Initial timing is correct.
Any help troubleshooting will be appreciated.
71 Nova [ready to race]
73 Cheyenne
90 Rexhall Vision RV
99 Town & Country
Old 08-26-2003, 09:47 AM
Re: 80 Olds driveability problem
ttt
I guess I shouldn't expect much. Heavy 4 door, 110 HP engine. Maybe an exhaust restriction? New muffler on it but cat might be plugged. Any way I can find out if exhaust is restricted?
73 Cheyenne
99 Town & Country
Old 10-16-2003, 06:41 PM
RABarrett RABarrett is offline
Muffler shops can check exhaust back pressure. This is the only reliable method. Ray
Old 12-01-2003, 08:12 PM
kpw olds kpw olds is offline
You might also try the secondaries on the carb. If they don't open (because spring tension is too high) the car will be gutless! Check an FSM to adjust secondary door spring tension. Typically, want the spring to just hold the doors closed + 1/4 turn....
Good Luck!
Old 12-03-2003, 01:01 PM
KPW- It's a 2bbl.
I advanced the timing in 2 deg increments and it showed a little improvement at 20 deg initial.
I have found out that these little Buick v6's suffer from timing chain/gear wear. Is there any simple way to check this?
73 Cheyenne
99 Town & Country
Old 12-09-2003, 09:48 PM
Slowly rev up and down the engine and watch the timing with a light--if its smooth, everything is okay, if not, its loose.
If in doubt, replace it. Its cheap insurance vs. being stranded somewhere...
2000 monte driveablity problems montecarlossfan Monte Carlo 4 08-01-2005 09:53 PM
driveability problem ksquare1 Caravan | Voyager 3 07-19-2005 12:51 PM
98 Lumina 3.1 driveability problem Bluenose Lumina 2 01-31-2005 08:22 AM
95 2.2 driveability problem intimidtr3 General Discussion 1 01-25-2005 12:46 AM
96 s10 2dr Blazer driveability problem will not rev over 2500 rpm scholzee Blazer 3 07-07-2004 04:48 AM
