Old 07-09-2005, 02:53 PM
ksquare1 ksquare1 is offline
driveability problem
As you drive vehicle it stall after acceleration when car is decelerating idle to low and then dies. Car starts immediately afterward already replace MAP Sensor no change. No check Engine Light On. Car has good power.
Old 07-09-2005, 04:23 PM
caravandrvr's Avatar
caravandrvr caravandrvr is offline
Sure sounds like a vacuum leak, or perhaps a leak in the air intake?
Old 07-09-2005, 04:53 PM
Stretch58 Stretch58 is offline
Re: driveability problem
You don't state what year or engine you have, but a 96 I had, with a 3.0 engine, I had to replace what they listed as an Idle Motor for the same symptom as you , typically I would come up to a stop sign and it would die. It would start right up as long as I kept the RPMs up.
Regards
Old 07-19-2005, 12:51 PM
thanks for help it turned out to be and bad egr valve with transducer
disconected egr valve and problem went a way.
