Old 08-14-2003, 12:46 AM
OneSikCRX OneSikCRX is offline
Send a message via AIM to OneSikCRX Send a message via Yahoo to OneSikCRX
dohc zc plug wires same as.......
are they the same as 89 integra ones, i know like almost everything else is the same, and i know tht a couple of you guys have this motor so any help would be awesome. thanks, donnie
Old 08-14-2003, 12:50 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Yes they are.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-14-2003, 01:02 AM
i imagine the valve cover gaskets are the same too huh?
Old 08-14-2003, 05:52 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
yuppers.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 08-14-2003, 05:53 AM
heres a parts list for the ZC:
http://dmoore.com/crx/zc.htm#ZC%20Parts%20List
ZC stuff
Old 04-21-2004, 09:25 PM
green mica green mica is offline
Found this thread during research. I purchased the integra wires (88' / Borg Warner) for my ZC (also an 88', I believe). They looked similar, especially in length, but the top of the boot would not sit snugly on the valve cover. I hacked a little of the rubber off and it still wouldn't fit. Then I took a bic pen and dropped it down the boot of the red sumitomo wires that came with the engine and marked it. I stuck the pen in an un-hacked 88' integra wire and the mark was about a half inch out of the boot. The metal connector at the spark plug is longer on the integra wire (despite identical "rubber" boot length). I hacked about a half inch of the metal connector and rubber off and the boot fit snugly. This may be poor design by borg warner, or my ZC is older. I'm not sure, but the 86-89 integra wires didn't fit my engine and I am trying to figure out which wires will (and how to return the ones that I hacked...). I am going to try 93' integra and 91' civic respectively. Bastard d-block twin cam. Any help on this topic would be much appreciated.
Old 04-21-2004, 09:27 PM
Re: dohc zc plug wires same as.......
89 Integra NGK wires fit my ZC just fine.
Old 04-21-2004, 09:43 PM
Retraction. Boot still did not seat properly, not "tapered" to ZC valve cover and butted up against it, leaving boot a half inch above the cover. Still confused.
Old 04-21-2004, 09:45 PM
difference between 88' and 89' wires perhaps? Can I paste pictures in a post of the difference in a post?
Old 04-21-2004, 09:47 PM
screw it, I'll just try the NGK wires. Thanks.
Old 04-21-2004, 10:25 PM
I guess this guy learned the hard way about Borg Warner too. Thanks again.
http://www.crxsi.com/resources/forum...1034081561.htm
Old 04-22-2004, 09:47 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
can u use the plug wires off a d15b2 as well? cuz i got NGK wires on my car and i wanna know if u can swap em when i do a motor swap because i'm planning on getting the dohc ZC motor
Old 04-22-2004, 10:11 PM
The NGK's that i got actually to sit off the valve over a few mm. Really, only two of them do, the other two sit flush. Im not too worried about it though, I know its getting good spark, it just doesnt fit absolutely perfect.
ZC stuff
Old 04-23-2004, 01:07 AM
unique head I suppose. Nobody likes gap in the boot. Another benefit of D block DOHC........just like the oil cooler by the filter.........
Old 04-23-2004, 01:20 AM
(possibly not unique to honda blocks --->) and the British Pipe Thread fitting (not NPT) out of the back of the block for the T-Fitting for oil pressure gauge hook up (unless I'm a complete idiot, which is definitely possible).............
Need Wiring info for E350 Cruise Module jdemaira Econoline 0 01-18-2011 02:16 PM
replaced my plugs and wires on my 2002 Gc sport 3.3 chevyn0va1 Caravan | Voyager 4 10-24-2010 06:38 PM
2002 Taurus DOHC Plug Wire Order LizzardLover Taurus | Taurus Wagon 5 12-13-2005 06:06 PM
sohc pistons same as dohc, right? lucki17 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 10 10-23-2004 02:12 AM
Do the type of spark plug wires you use matter as long as u go performance... 94VtecLude Prelude 1 11-02-2003 01:43 PM
