sohc pistons same as dohc, right?
if i buy after market pistons for a dohc they fit sohc right? thats what ive heard anyways, if not does anyone know a link for sohc pistons? i want some lower compression ones for turbo.
Someone said that SOHC pistons in a DOHC raises compresssion to 9:1.
Re: sohc pistons same as dohc, right?
early 89's had 8.6:1
the rest of the sohcs had 9.1:1 all dohc's had 9.5:1
yes the pistons will interchange.. its sort of a cheap mod to do for some more horsepower if ur running N/A..... or even small amount of boost
edit* thats SOHC pistons into a DOHC block.... Last edited by SR20DETpower; 10-21-2004 at 11:34 AM. |
Actually The Sohc Pistons Raise The Compression Of A Dohc Over 10 To 1 (although I Forget The Exact Number)
IF I AM TYPING IN CAPS (LIKE NOW) I AM SORRY BECAUSE I AM AT WORK (DATA ENTRY) AND I HAVE NO CAPS LOCK BUTTON AND NO WAY TO CHANGE MY UPPER CASE LETTERING. SORRY! EMAIL CONTACT: [email protected] |
so does that mean i could put dohc pistons in my sohc and it would have lower compresion? are they strong enough to run a good psi (like 12 or 15)
whats DOHC stock compression? 9.5:1 or 9:1? and i also heard this guy toop KA24E pistons and put in his KA24DE and had 11:1 compression
Yes You Can Use Dohc Pistons To Lower The Compression..... Its A Common Swap Because Its Cheap.
do i have to take out the engine to change those or can i do it in car?
cool thanks, sounds like a fun weekend project.
