Old 08-13-2003, 02:29 PM
FiaCobra FiaCobra is offline
73 Duster ignition ?
I need to replace the ignition key cylinder on my 73 Duster since the key no longer works. The ignition is in the "off" position and i need to know how to remove it without causing damage to the steering column. Can it be drilled out or does it have to be removed using a slide hammer?
Old 08-14-2003, 10:54 AM
Ok, i drilled out most of the key cylinder and can get the steering wheel to unlock. What i need to know is, if there is a pin holding the cylinder in place. I need to remove the cylinder inorder to replace it.
Anyone??
need ignition coil and tune up advice jgn Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 07-21-2009 09:26 AM
Ignition Coils on C280 andante147 C-Class 1 06-05-2009 05:57 PM
2000 m/c ss ignition control module problems ABADTAZ Monte Carlo 1 05-03-2009 03:53 AM
1973 el camino- electronic ignition. HELP Landmeier El Camino 3 04-14-2009 09:33 PM
Ignition Lock Cylinder & Worn Keys... Intuit Escort 2 02-18-2009 10:51 AM
