Old 08-12-2003, 07:11 AM
joeyo joeyo is offline
Send a message via ICQ to joeyo Send a message via MSN to joeyo
Light grinding noise
Hey All,
For the last week or so I've been hearing a light grinding noise when I made right hand turns. The noise doesn't happen all the time, but only sometimes when I'm really turning the wheel (like pulling into my parking spot)
I thought I read somewhere that this is a CV joint problem? Does anyhow know how much it costs to fix this?
Thanks
Joey
Joey
Old 08-12-2003, 07:29 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
My car had a similar noise. In my case it was a scraping metallic noise in turns. I found rust had formed on the edges of the rotors and was touching the brake splash shield. I just ground off the rust and I was all set, cost $0.00.
Old 08-12-2003, 07:33 AM
origamiguru origamiguru is offline
Grinding?
Hey man,
does it make kind of a clicking noise as well? I've replaced both my axles from having CV joints wear out (and make a grinding/clicking noises). a rebuilt axle is about $120-150 CDN, and it shouldn't take more than an hour to replace.
If you have access to a hoist, or feel like crawing underneath your car with a flashlight, check near your front brakes (on your axle) and look for a torn rubber boot. if you find that it's cracked somewhere, then you can be pretty sure it's your axle.
Hope this helps man,
-Adam.
Old 08-12-2003, 07:36 AM
Yah it's sort of a light grinding/clicking noise now that I think about it. Like it isn't really all that loud, I have to have the radio off and the window open to hear it.
I'll crawl under the car when I get home and have a look. Thanks for the info!
Joey
Joey
Old 08-12-2003, 07:40 AM
sackerius's Avatar
sackerius sackerius is offline
so far seems like CV's... who knows tho... check it out and get back yo us..
also its not too big of a fix... set ya back im think 120$US.. or am i wrong?
Vehicles I Currently Own
- 82 Toyota Tercel/Corolla (daily driver... o it kicks ass, lights the tires up real good hah)
- 88 Civic 4 door LX (not running, not sure what im going to do with it, race car, sell parts, sell?)
Vehicles I Have Previously Owned
1 - 85 Plymouth Caravelle
2 - 90 Civic Cx
3 - 83 Chevrolet S10
......And just for fun.... this makes me laugh every time.
image removed by moderator
Old 08-12-2003, 02:14 PM
If it is the CV's should I just replace the whole axle or just the CV joint?
Joey
Old 08-12-2003, 09:21 PM
johnb16a2's Avatar
If it is your CV joints just replace the whole axle. It's usually not much more expensive to replace the whole axle and it's alot easier than messing around with the joints.
Old 08-22-2003, 01:45 PM
Well it turned out one of my calipers was seized up and was the cause of the noise. I had to replace the caliper, pads and rotor.
Sometimes owning an older car is such a pain in the ass. She's lucky I love her.
Joey
Old 08-22-2003, 02:41 PM
frozen_Joth frozen_Joth is offline
Easily Distracted
Send a message via AIM to frozen_Joth
My car made a real bad clicking noise for a while and still does sometimes. I had to replace my brake pads before anything else and now the clicking noise doesn't happen as often as it did. I hope my joints last until I get my engine swap (Next Month)! I've always heard they were good to ride on until they made that clicking noise going straight.
'92 blue Civic Si
-B17a
-Carbon fiber intake, full exhaust
-Short throw, lowered
2001 Accord Manual --weird hissing / grinding noise from Back seat area! shivparekh Accord/TSX/Accord Hybrid 7 01-10-2010 07:42 AM
98 Stratus Grinding Noise pcjunkie7 Stratus 4 06-22-2009 07:21 AM
1999 Ford Expedition (E.B. Edit.) -Loud Grinding / Crunching noise in first gear UnluckyDucky Expedition 0 03-13-2009 06:03 PM
light grinding noise when started? ghostrx7 RX-7 7 12-18-2006 11:37 PM
Few things, brake pad light,grind noise in wheel MyAudiStinks General Discussion 2 01-04-2006 04:47 AM
