Old 08-11-2003, 10:33 PM
850turbo 850turbo is offline
Send a message via AIM to 850turbo
clear coat?
ok, for the skyline model that i am planning to make i will be using tamiya primer, and tamiya base color paint. since this is my first time trying the painting process explained in the FAQ i want to use a clear coat on top of the base coat.
what should i use for the clear coat?
thanks
Old 08-11-2003, 11:45 PM
MR-2RaCeR's Avatar
MR-2RaCeR MR-2RaCeR is offline
Send a message via AIM to MR-2RaCeR
Testors clear coat works pretty well, there seems to be no problem with it, but i use Tamiya, although it might melt your paint just a tiny bit when applied.
-Henry-
Old 08-12-2003, 12:04 AM
ZoomZoomMX-5's Avatar
Use Tamiya clear. Testors isn't nearly as good.
My Fotki Album
Old 08-12-2003, 12:38 AM
hobbes874's Avatar
hobbes874 hobbes874 is offline
Send a message via AIM to hobbes874
Tamiya clear, seams to work good and no paint problems over Tamiya lacquer
All Newbies please read the F.A.Q's
"We are defined by the choices we make." -Fight Club
Old 08-12-2003, 12:56 AM
ok, going to use all tamiya stuff, from beggining to end. tamiya primer, tamiya color, and then tamiya clear coat. will this work well?
also, is is possible to get tamiya polishing compound in the US?
thanks
Old 08-12-2003, 03:07 AM
ShOrtyOC714's Avatar
ShOrtyOC714 ShOrtyOC714 is offline
=p
Send a message via AIM to ShOrtyOC714
Just some advice, when u spray the clear coat on, spray in light coats, and remember to let ur base coat of paint dry about 2 hours, and then move on to clear, if u do not let the base dry it has a chance of melting the base coat paint, i know all of this from experience.
Old 08-12-2003, 05:22 AM
Ragnarok043's Avatar
Ragnarok043 Ragnarok043 is offline
Send a message via AIM to Ragnarok043
ive actually had no prob with Tamiya Clear over Tamiya Acrylics and i sprayed on about 3 heavy coats. the key is to make sure the base coat is thoroghly cured, i let mine cure for about a week.
Old 08-12-2003, 06:51 AM
Martbee Martbee is offline
That is my combinaison and it work well... but I don't know why, this */%king RX-7 has never hardened !
Can you explain this:
2 coat of fine Primer Tamiya, 3 coats of X6 Yellow Tamiya then 2 coats of Clear X22 Tamiya, I let dry for a week and the masking tape (Tamiya of course) is still making it's traces when applied on top of this former marvelous machine ???
That's the way I always worked before but this time, it's not hard enough, my fingerprints are digging without any effort in the finish.
Have they changed their receipe? Is it too humid? What's the matter with this?
So now, I have to put another coat (or several) of Clear to erase all the trouble I had. The pain, the RX-7 was done but now I have to redo the Clear or peel off everything and redo all the things that was done !
Old 08-12-2003, 12:30 PM
what about testors clear laquer? has anyone used this?
Old 08-12-2003, 12:34 PM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
I use the Testors and it works really well. I don't really have a choise though, my closest hobby shop is like 8 hours away, so I have to use what I can get at Wal-Mart and stuff.
Old 08-12-2003, 04:32 PM
tdoty tdoty is offline
First off, the Testors will turn yellow over time. Secondly, it doesn't spray nearly as well as the Tamiya. Thirdly, it takes longer to dry - and that means a bigger chance of getting dust in the clear coat.
Just my experiences.
Tim D.
Old 08-12-2003, 05:11 PM
malsheem's Avatar
malsheem malsheem is offline
20 inches and growing ...
thanks
I've used Tamiya primer, spray cans, clear coat, rubbing compound, and wax exclusively since I've started building. I've never had any problems with them at all. I recommend them completely.
Rubbing compound is available in the US. Just check Tamiya USA's website for a listing of hobby stores that carry plastic model stuff. They should have compound. If not, try online, www.hobbylinc.com is a good place.
-Joe
www.quietrage.com
CWest R34 Skyline GT-R
Old 08-12-2003, 07:39 PM
aight, i think i'll stick with tamiya. i myself have always had good experiances with tamiya products, and it seems the same for most other people on this board.
thanks for the advice though, i really appreciate it.
