Old 08-10-2003, 01:26 PM
850turbo 850turbo is offline
Send a message via AIM to 850turbo
RAYS engineering in 1/24
i was wondering if anyone knows if these wheels are made in 1/24 scale and if they would fit on a tamiya R34 skylyn kit?
also, how would i go about painting them to get that exact finish?
thanks
Old 08-10-2003, 01:43 PM
blueboost's Avatar
blueboost blueboost is offline
you can get those wheels out of another tamiya kit like say the raybrig NSX. the NSX wheels will have two large rims out in the rear and two smaller width rims for the front. now for the R34 you may want all 4 rims to be the wide variety depending apon the kit.
what you can do is go to this site..
http://www.tamiyausa.com/product/pla...ies/index.html
then click the various cars to view the rims that come with them. if you find the RAYS rims you like you can then call tamiya and order the rims and tires directly from them, just jot down the part# of the kit the wheels are from. as far as painting them, I'll leave that part to someone else who may have a better idea how to go about that. I believe the loctite car would be the most appropriate being that it has RAYS rims and they will be the correct width since they are from a skyline kit
heres the loctite
http://www.tamiyausa.com/product/pla...ies/24225.html
Old 08-10-2003, 02:07 PM
ShOrtyOC714's Avatar
ShOrtyOC714 ShOrtyOC714 is offline
=p
Send a message via AIM to ShOrtyOC714
heres the loctite
Why would u go buy a kit for just the rims??? thats stupid, they sell Volk TE37's from Fujimi, they sells thoses in 17in. and another kind Volk TE37 Mags, in 18 in. Go to HLJ.com
Old 08-10-2003, 04:00 PM
Jay! Jay! is offline
Horizontally Opposed
Re-read his post.
Hierarchy of Subaru:
(Click to see mine!)
Old 08-10-2003, 04:11 PM
blueboost's Avatar
Originally posted by jay@af
Re-read his post.
Old 08-10-2003, 05:32 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Regardless, I think it'd be better to go ahead and just get the Fujimi rims since they have decals for "Volk" and "Rays." www.hlj.com is a good source, and they should have them in stock since I just got in a set (1.5wks delivery, btw.). As for that finish.... I'm not sure. They come molded in white. I'm thinking about that now, since I want them that color. I'm thinking about painting them black, then dusting gold over, then coating it with some Tamiya clear orange or something. That's going to take alot of experimenting to get right though. I'd prolly be better off just finding some Testors bronze metalizer or something like that.
Old 08-10-2003, 05:40 PM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
The only touble with using the Tamiya ones is they have the central nut not a 5 stud fixing. This is the problem I have on a set on Enkei rims at the moment.
Steve a.k.a. Hiroboy
Old 08-10-2003, 05:46 PM
blueboost's Avatar
pro's and con's to both our ways of going about this. your idea would probably wind up with a better more realistic rim (use the fujimi rims with decals) but will take a lot of work, you have to convert them from female to male and also its a b!tch getting a nice 17-19 inch looking wheel from fujimi, most times they look like 13's with bo-bo tires.
My way you aren't going to get the RAYS decal with the rim, but you will have a better fitting rim that requires no modification and will be stronger
Old 08-10-2003, 07:55 PM
True. I guess it depends on what you want in the end, and how much work you're willing to do. I don't know what the fuss is about converting rims, though. Personally I don't worry much about it. I just trim some of the female part off the Fujimi rim, enough for it to butt up against the Tamiya suspension part. Then I drill out the Tamiya brakes so that I can slip it over the Fujimi rim connecter doo-hicky. Then I take a peice of sprue that slips in where the vinyl nut goes on both the rim and the car, and epoxy it in place, holding on the rim. They don't turn but I don't care. It works, is simple, and looks just fine. But still, using the Tamiya rim is easiest.
And I'm not arguing-- I just enjoy seeing diffent viewpoints and techniques and stuff.
Old 08-10-2003, 08:21 PM
hm...
i'd prefer to use tamiya wheels, cuz they are made to fit. but is there any way to change the central lug to a 5 lug designe?
any ideas would be great
thanks
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
