Old 08-09-2003, 09:52 AM
grumpee grumpee is offline
Which gear oil to use??? Please advise!
I own a JDM Honda Integra Type R 96 Spec. I was just wondering which gear oils would be good for my car considering that i have (jdm helical l.s.d, jdm gear box). Are synthetic oils good for honda trannys? I heard that the redline shockproof gear oils are no good for hondas. Please advise. Thanks.
Drive fast, die faster, so what? I Like....
Old 08-10-2003, 11:03 AM
1mugencrx 1mugencrx is offline
use honda mtf
use the honda mtf (manual transmission fluid). it comes in a gray bottle. do use synthetic on a good tranny. only use synthetic, such as redline shockproof, when the synchros are messed up. in these cases, the synthetic/thinner oil will help lubricate the synchros better and get rid of grinding problems.
1992 Civic HB Si
B20 vtec w/: ported and polished B16A head, CTR LSD tranny, Exedy clutch, CTR cams, JE 10.8:1 compression pistons, Type R intake manifold, Portflow valve springs and retainers, AEM cam gears, AEM CAI, JDM Type R header, JG throttle body, AEM fuel press. reg, AEM fuel rail, Apex'i VAFC, ACCEL plug wires, Denso Iridium plugs, 5Zigen exhaust, etc.......
Lakers Rule!!!
Which gears to use? TruthSeeker TrailBlazer | Trailblazer EXT 6 01-31-2006 01:29 PM
which gear oil to use for differential steve420 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 09-10-2005 11:22 AM
Which gear oil for 03 Dakota V6 4wd 5sp nettiebaby24 Dakota 2 06-29-2005 02:10 PM
please advise immediately - gears stuck in park - cannot shift gear! laura_tejeda Jetta/Vento/Bora 2 08-26-2004 10:36 AM
I want to use Mobil1 oil, Please tell me which brand oil filter is better, K&N or Mob ouyangcui Integra 3 04-25-2003 12:05 AM
