Go Back   Automotive Forums Car Chat > Mercedes-Benz > E-Class
Old 08-07-2003, 10:24 AM
TwoBlackDog TwoBlackDog is offline
E320 Dash Light Replacement
Dash light left-most side of dash is out. How to remove dash to access light socket and replace? Need special tools, if so, what are they? Many thanks.
Old 08-08-2003, 10:34 AM
jays vdub jays vdub is offline
Send a message via AIM to jays vdub
i work at a benz dealer and there is a special tool to remove it just be careful when taking it out of cracking the plastic, call your local dealership the parts guy should know what it is good luck
slammed cammed and exhausted
Old 11-19-2003, 02:18 PM
pkmaven pkmaven is offline
Re: E320 Dash Light Replacement
The Special Tool, available (pair) at any MB parts window, will allow you to insert on both sides of the plastic pod, between it and the dash, allows you to turn and gently but firmly pull forward. It's a friction fit. Tool part number:140 589 02 33 00. P.
Old 05-10-2004, 08:34 AM
greystone's Avatar
greystone greystone is offline
Question Re: E320 Dash Light Replacement
Say Jays, I just got a 2000 E320 and am having trouble seeing the dash lights at all in daytime. You know-- the led box with odometer, and trip meter, and all the little messages that are supposed to be useful, but totally unreadable in any sunlight. Is there an upgraded set of brighter bulbs I can get for this?
Thanks in advance. Greystone, Austin, TX
Old 05-12-2004, 07:23 PM
MB tech MB tech is offline
Sounds like the bulb's are blown in the message board. They should actually light up brighter in the day than they do at night. I do not think that anyone makes these in a brighter bulb either. You can pull the cluster out and check if they are blown there are clear and red bulbs for the display.
Hope this helps
Old 05-13-2004, 10:08 AM
greystone's Avatar
Re: Re: E320 Dash Light Replacement
Originally Posted by MB tech
...They should actually light up brighter in the day than they do at night. ..
MBTech: Thanks for the tip. I took the car into a local MB dealer and had them look at it to see if there was something out of whack. Seemed normal to them, so I asked to see another 2000 on the lot and compare the displays. Exactly the same. I cannot believe people who buy into the quality of MB would not have been more vocal about this particular bug. My tan interior reflects so much glare back onto the instrument glass that it is almost dangerous to try getting the correct angle with your head to see the odometer and trip information. Polarized sunglasses actually make it worse-- AND polarized lenses make the radio LCD screen completely unreadable. Grrrr. Great car with little bugs.
"You need to be careful if you don't know where you are going, because you might not get there." Yogi Berra
1998 Monte Dash Lights Will No Longer Work... ermiller79 Monte Carlo 0 12-08-2009 07:35 AM
98 Camry Dash light replacement grandparabbit Camry/Camry Hybrid/Vista 7 08-12-2006 01:19 PM
E320 Dashboard light replacement bouncepass2 E-Class 1 03-28-2006 08:31 PM
'92 325i dash light replacement, power antenna, soft top questions johnqin 3 Series 3 08-03-2004 09:27 AM
2003 Dash Light Replacement DamBigBuck Caravan | Voyager 0 01-16-2004 03:49 PM
