Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-06-2003, 07:27 PM
grandparabbit grandparabbit is offline
Question 98 Camry Dash light replacement
Does anyone know where I could find some web based information on how to get to the dash lights on my Camry? I have dash lights out on the heater controls and the tach side of the dash panel. I can't afford the stealership charge this close to Christmas, so free advise would be appreciated.
I replaced the indicator light for the transmission indicator (auto) and I'm hoping this is a little easier.
thanks,
grandparabbit
Old 12-11-2003, 01:13 PM
Drewstoycam Drewstoycam is offline
I no about the tach light
Hey all you need to do is get some new 194 bulbs , remove the housing around the guages, and pull our the intrument cluster. behind the cluster is little green things that turn these are the bulbs. Pull out and remove the burn out bulb. This is also a good time to check your other bulbs. Replace the new bulb and place back in and your done
Any ?'s just ask
Drew
and also mayeb time to do some painting
check out what i did
Old 12-12-2003, 11:36 PM
dongta dongta is offline
Re: 98 Camry Dash light replacement
Hi Drew,
How could I open the dash to access the gauge area just like you did - for my 93 camry? I got a reverse glow gauge and would like to do it myself, but could not find the correct screws to get to the gauge. I greatly appreciated for your help.
Hoang
Old 01-20-2005, 02:01 PM
sixesnsevens sixesnsevens is offline
Related Question
The illumniated "D" on the gear indicator has gone out in my 1995 camry. Is it possible to access and replace the bulb.
Old 08-12-2006, 09:18 AM
iflyjets7706 iflyjets7706 is offline
Re: I no about the tach light
Any ?'s just ask
Drew
Drew,
Besides taking out the two top screws, what tools did you use to remove the clips from the ends and bottom of the housing? I took out the two screws and the ends and bottom would not budge.
Thanks
Old 08-12-2006, 11:52 AM
KimMG KimMG is offline
AF - Advisor
Did you try the service manuals available at the top of this forum?
Old 08-12-2006, 11:53 AM
AccordCodger AccordCodger is offline
iflyjets7706. this thread was old even before sixesnsevens woke it up.
Drew's last post was TWO YEARS ago. I doubt he is still reading questions like yours.
Old 08-12-2006, 01:19 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Originally Posted by iflyjets7706
Drew,
Thanks
If your car is also a generation 4, there are 2 clips at the outside of the little "wings" on the gage cluster cover. I used a hook like tool, similiar to a dental pick with a right angled bend and pulled straight outward right by the clips. You could also use a small slotted screwdriver taped to protect the vinyl and pry right by the clips.
Here's a link with some great pictures on the whole process:
http://www.imagestation.com/album/?id=4291310149.
Mike
