Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-07-2003, 08:36 AM
augtenth augtenth is offline
Arrow Uneven Tire Wear
My car is lowered and I get uneven tire wear on the front tires. The inside edge wears faster than the outer edge.
How can I correct this?
Old 08-07-2003, 12:51 PM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
a camber kit will solve the prob
Old 08-07-2003, 08:23 PM
S1 Type-R's Avatar
S1 Type-R S1 Type-R is offline
Send a message via AIM to S1 Type-R
Yeah a camber kit will correct the problem....I hear good things from the Skunk2 camber kit...
2001 ITR
WWW.SQUADONE.NET
Old 08-08-2003, 10:18 AM
DCNo07 DCNo07 is offline
skunk2 camber kits are expensive, you can get ingalls camber kit for front and rear for about $150 i think..... dont drop alot of money on a nice looking camber kit it all does the same thing. lol my buddy has a 92 teg and he just used 2 3/16 washers to correct his camber. but i guess that only works in the rear.
Old 08-08-2003, 12:06 PM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
yea the rear control arm is different.
you can put washers under it to push it out and correct camber for like 30 cents for each side of the car lol.
like that ^^
Old 08-09-2003, 02:26 AM
tran_nsx's Avatar
i wouldn't reccomend adding washers to fix a camber problem, its cheap, and works for right now but i think u'll pay for it later on. one example was cutting stock springs or heating them to make them look lowered, eventually those springs will screw up ur suspension and u'll gonna wasting more money trying to fix that. but coming back to the camber kits, don't be cheap get good quality craftmanship it will definately be worth it, especially when u have to take it to get an alignment check.i don't even think a shop would even touch your car if they see washers, they'll probabaly turn u away and laugh at u after u leave.i heard of skunk2 but but after asking around which are the best i have to say ingalls, its also been used by a lot of professional racer too so i know i can get something i can depend on. the price varies from shop to shop but they aren't cheap just to let u know, its like 150+ for the front and like 80+ for the rear not including installation then the price of alignment to fix the camber. this might sound a lot but it will save u a grip of money over the long run, better then getting new tires every 6 months thats for sure.
Old 08-09-2003, 12:22 PM
S1 Type-R's Avatar
True that! you get what you pay for.
2001 ITR
WWW.SQUADONE.NET
Old 08-09-2003, 10:24 PM
strangerover strangerover is offline
I used Ingalls on my 95 GS-R with a mild 1.25" drop. The stock rear upper control arms get replaced with threaded adjustable length ones. The front Ingalls camber kit replaces the stock upper control arm pivots with slotted adjustable length ones. Careful, though, there are different kinds depending on how many degrees of correction you need, so get the right one. They also come with either rubber or urethane bushings. I went with the rubber ones because I have had nothing but shitty experience with urethane bushings (noisey as f***k in short time). When you lower these cars, the toe angle of the wheels goes out, and that rips tires up, besides making the car feel squirmy. Get the Ingalls kit and get the best alignment you can. Make sure they adjust caster, camber, and toe. This takes some time so make sure they do it right. Oh, yeah, you need new tires. Once they wear unevenly like that, they're never the same.
Old 08-11-2003, 06:55 PM
raileb raileb is offline
not to say ur all wrong about adding washers behind ur controle arms. but that is the cheepest way to do it and its not ever going to mess anything up in ur suspen. they wont hurt a thing trust me its just like adding shimmmmms into the front of an old car such as a 64 ford they add shimmms to correct camber.lol
Help !!! Uneven Tire Wear Problem..... Car Guy 323/Protegé/Familia/Etude/Allegro 3 08-23-2004 08:52 AM
Help!!! Uneven Tire Wear Problem..... Car Guy Tires and Wheels 5 06-18-2004 03:51 PM
uneven tire wear... aznjeep C/K 1 06-06-2004 05:46 PM
uneven tire wear Mac8008 3 Series 1 02-06-2004 10:40 AM
Uneven tire wear on '92 525i mccurryct 5 Series 1 01-06-2004 06:54 PM
