Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-07-2003, 03:45 AM
Bossman Bossman is offline
92 camry, reverse lights quit
The reverse lights on my 92 Camry stopped working. I checked the fuses and changed the light bulbs but that didn't help. Every once in awhile they will come on for a few short seconds but that's about it. Any help would be highly appreciated. Thanks.
Old 08-09-2003, 07:10 AM
Well, I learned from another forum that the problem may be the "neutral safety switch" in the auto transmission. I understand that it the part itself is about $200. Is it worth making the repair considering labor cost is going to be high too?
Old 08-15-2003, 10:02 PM
kaskillah's Avatar
kaskillah kaskillah is offline
Re: 92 camry, reverse lights quit
You might want to test your neutral switch with a test light first before you think about changing it. I thought that it was the problem in my '92 Camry I used to have. It wasn't. The switch tested OK. There was a short somewhere in between the switch and the b/u lamps. Never did find the short, (too many wires) instead I ran a new wire from a wire I found that would light up the test lamp when I put it in reverse.
This is what you may have to do. It's the cheapest route.
Old 08-16-2003, 12:46 AM
Re: Re: 92 camry, reverse lights quit
Kaskillah,
Thanks so much for the info. I wouldn't have thought of that but I'll certainly try it before putting $$$ into a new switch.
Old 09-05-2003, 12:32 PM
GTS91's Avatar
GTS91 GTS91 is offline
See if the wires where the trunk hatch closes aren't torn or shorted
(right on the bend where trunk lid meets the back frame of the car behind back seats.. ) .. on 96 Camry my mom run into this problem but with all the lights eventually - one after another.. wires were too tight & stressed - I heard it's a prob on some 96's..
doesn't hurt 2 try it...
Old 09-06-2003, 12:25 AM
GTS91,
Thank you very much. I'll check it first thing in the morning.
rear-light warning signal and reverse lights up on brake 1993 Camry LE V6 patmanj20 Camry/Camry Hybrid/Vista 7 07-24-2008 01:01 AM
HELP ---93 camry- reverse light comes on when i hit the brakes honda978 Camry/Camry Hybrid/Vista 2 04-20-2006 02:57 PM
2001 camry tail light and reverse light not work williamwu2000 Camry/Camry Hybrid/Vista 1 01-26-2006 01:50 AM
95 Camry reverse light gator2764 Camry/Camry Hybrid/Vista 2 12-21-2005 05:36 AM
98 Camry XE, I4, reverse lights not working rpmglide Camry/Camry Hybrid/Vista 3 03-10-2004 06:23 PM
