Old 08-07-2003, 02:34 AM
AnthonyCloud9 AnthonyCloud9 is offline
Send a message via AIM to AnthonyCloud9
Exclamation drain plug
I have a problem with my drain plug. When I took it out to drain my oil, the thing wouldn't come off easily. When it finally came loose, the bolt just kept turning when I tried turning it. So I was able to get it out with the help of my bro. It turns out we had to strip most of the bolt just to get it out. Now when I put the new one in it doesn't tighten all the way and it just keeps turning again. Now its leaking. Can this problem be resolved by making new threading on the oil pan? I could use the help cause I don't want to end up putting a quart of oil everyday.
w00t
Old 08-07-2003, 04:01 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
just rethread the current hole alittle bigger and get a bolt to match
Team Lonely Drivers
Old 08-07-2003, 05:30 AM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
ud need a short bolt to replace it, cause there are moving parts in there.
Old 08-07-2003, 07:16 AM
sackerius's Avatar
sackerius sackerius is offline
yah true.. just match up the new fatter bolt, with the old one, and make sure its the same length... then ur good to go
Vehicles I Currently Own
- 82 Toyota Tercel/Corolla (daily driver... o it kicks ass, lights the tires up real good hah)
- 88 Civic 4 door LX (not running, not sure what im going to do with it, race car, sell parts, sell?)
Vehicles I Have Previously Owned
1 - 85 Plymouth Caravelle
2 - 90 Civic Cx
3 - 83 Chevrolet S10
......And just for fun.... this makes me laugh every time.
image removed by moderator
Old 08-07-2003, 07:52 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Most auto parts stores carry a special rubber plug especially for this problem. The oil pan is made of sheet metal and I don't know if you can cut new threads into them. Good luck.
Old 08-08-2003, 03:43 PM
Arrow rubber plug
I used the rubber plug, but its leaking really small drops. I'm not really concerned buy what do you guys think. Its not leaking close to how much as it was before, just droplets. The weird thing is, its dropping through the bolt rather than around the rubber. Weird.
w00t
Old 08-08-2003, 08:23 PM
BullShifter's Avatar
There are over-sized plugs & toggle bolt style plugs for stripped pans. Auto parts stores carry them. The correct way to fix it: replace the oil pan
Old 08-08-2003, 08:39 PM
johnb16a2's Avatar
That's the best solution.
2001 Durango 4.7L radiator drain plug mcknt Durango 0 09-26-2009 12:52 AM
How Many Quart of ATF drain if open Drain plug chuckLee Cedric | M45 | J30 | Gloria 0 12-22-2003 02:51 PM
v6 anti-freeze drain plugs mekeelw General Discussion 0 09-25-2002 12:09 PM
Engine block drain plug??? Help! vikon Maintenance 2 07-04-2002 03:46 PM
Magnetic Oil Pan Drain Plug Yahnozha Engine 4 02-27-2002 12:04 PM
