Old 08-06-2003, 03:36 PM
euroAccorDeuro euroAccorDeuro is offline
My car wont start, IM STRANDED, please help!!!
My car wont start, this has never happened before. I mean sometimes it wont start, but i figure i just flooded it, wait like 5 mins and it starts. Well i been waiting like 20 mins, damn thing wont start. It will turn over, but will not actually start. I don't think it's the battery, cuz my 15 will still hit, and i know that takes a lot of power. Please help. I'm stuck at my friends house.
Old 08-06-2003, 03:51 PM
Accord_Zero's Avatar
Accord_Zero Accord_Zero is offline
Send a message via Yahoo to Accord_Zero
What mods have you done? Anything with ignition? Mine did the same, but it was my battery...some lights still worked though, so that threw me off.
Old 08-06-2003, 04:07 PM
All i have is exhaust, and some others, but nothing ignition. I just went out there. I started it like 6 times, it started every single time. I have no idea. I know its gonna happen some time in the future tho again. Thanks for the help tho man.
Old 08-06-2003, 05:48 PM
Strange...glad to hear it's starting again. But like you said it might happen again soon. How old is the battery? And does the battery light come on at all?
Old 08-07-2003, 11:56 AM
Well when i have like the key turned to accessory or whatever its called, when the cars not on, but the lights and cd player works and everything, the oil light and battery lights light up. But i just changed the oil, so i know its not low. So i'm guessing they just come on all the time when the car is off. Cuz when i turn it on, they go off. I don't think the battery is bad. I mean it has no trouble turning over, but it just doesnt start.
Old 08-07-2003, 01:26 PM
Mine was doing the same thing, but not everything worked while the key was in the first postition. But how many miles has it been since you changed the battery?
Old 08-11-2003, 01:43 PM
xplode xplode is offline
Send a message via AIM to xplode
get new spark plugs, and get your engine checked..
Old 09-19-2003, 12:51 AM
icechopper26 icechopper26 is offline
Have you figured out this problem yet?
Old 09-20-2003, 12:07 PM
scarecrowdjinn scarecrowdjinn is offline
Its sounds kinda of like your "main fuel relay". Do some research on the web, and this/other forums for it. If you can't find any thing let me know, I have a site or two talking about this, unfortunaly i'm at work and Don't have them. Good luck.
Old 09-20-2003, 11:00 PM
No, i havent figured out the problem, ive been two busy worrying about coming up with the money for my swap. Do you know how hard it is to come up with 4 grand when ure 17? I dunno, ill been changing the plugs soon, and maybe everything will work out. (Ya, like that EVER happens)
4th Gen Accord
Mods:
2 1/4" Custom Cat-Back Exhaust
ADR 18's
Custom Painted Interior
Custom Spare Tirewell Box
6 1/2" Component Speakers
15" Audibahn Sub/ 800 watt bridged amp
Short Ram Intake
Future Mods:
H22a Engine Swap
Manual Conversion
Coilovers
Old 09-22-2003, 05:06 AM
aesani aesani is offline
Honda not starting?
Does the engine just crank and crank and not start?
If so, get your starter and selenoid checked.
If it just goes "clunk" or "click, click" and nothing happens change your battery.
Also, change your distributor cap, rotar, spark plugs and wires.
Wouldn't hurt to change your fuel filter either.
Good luck.
Old 09-22-2003, 09:43 AM
doylna doylna is offline
Re: My car wont start, IM STRANDED, please help!!!
It's more than likely your main relay. They tend to short out and when it's hot, or the passenger compartment is hot, the engine will turn over but won't start, because the relay won't relay correctly. You can replace the relay yourself in about 20 minutes. It's located under the dash in the left hand side, behind the change tray. It's a $50 part depending on the dealer. Check out these links
http://autorepair.about.com/library/.../aa010301a.htm
http://autorepair.about.com/gi/dynam...main-relay.htm
http://www.autorepair.about.com/libr...y/bl_hmr-1.htm
The last one shows you pictorially how to replace the relay.
Old 09-22-2003, 08:09 PM
Thanks a lot, ill look into changing the main relay while my car is sitting in the garage all winter.
4th Gen Accord
Mods:
ADR 18's
Short Ram Intake
Future Mods:
H22a Engine Swap
Manual Conversion
Coilovers
Old 09-23-2003, 09:21 AM
I finaly found the site I mention in my pervious post.
This site actualy tell you how to fix the old relay, so you don't have to
spend money on a new one.
http://techauto.tripod.com/mainrelay.htm
I did it my self 3 months ago, and I haven't had a problem since.
Good Luck.
craig
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
Car wont start or charge- HELP... qutiee22 Engineering/ Technical 2 03-07-2005 05:23 AM
Car wont start can somebody help me? slowhand_4276 Cavalier 5 10-31-2004 03:48 PM
Car Wont Start I Need Help Bad phillyphil Camaro Discussions 7 11-08-2003 02:58 PM
My car wont start, need some help. plkelley '88 - '91 Civic | CRX | Wagon | Shuttlee 15 09-12-2002 08:29 PM
