Old 08-06-2003, 11:15 AM
gsf1200m gsf1200m is offline
a/c conversion done, have questions
I got the conversion kit from walmart that says its to convert r-12 system to r-134.
It went in easy, everything works, and the air is really cool.
It seemed a little easier to do from what I have heard from other people so im a little worried.
But my real question is...
I can hear an air leaking sound from around the compressor area when I turn the car off.
I checked the pressure after about 15 minutes and It was still the same.
Is this a leak?
Is this something I did wrong or do I need a new compressor, hoses.....?
Old 08-06-2003, 11:21 AM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
That system is under such high pressure that any leak would lose the refrigerant rather quickly. Sounds like it's workin' fine.
Flunky
Old 08-06-2003, 11:36 AM
Ok sweet.
Ill keep checking it but sounds good to me for now.
After 2 years without it, its good to have a/c again.
Old 08-06-2003, 11:44 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Hmmmm...did u evacuate the old R-12 completely out of the system? The two oils in r-12 and r-134a are NOT compatible and would probably ruin something in the system pretty quickly...
Another thing I have heard is that R-12 Dryers on not compatible with R-134a either....and that part should be replaced when you do the conversion. I would hope that a newer dryer from a newer Civic in a junkyard running r134a would satisfy this
There was some pretty in depth discussion on this topic - I think this is the link to it - http://www.automotiveforums.com/vbulletin/t114283.html
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 08-06-2003, 05:51 PM
Well I found out where my leak is.
Its on the very right edge halfway up the condenser when you are looking at it.
This is why it crapped out in the first place i guess.
I just replaced my radiator and it looks like it would have been easier if i knew about it then and done them both.
Have you seen this? Tom Hanks converted car to electric? 1967mustang Car Videos 1 11-23-2009 09:27 AM
twin turbo conversion done! with pics! Zeiss 3000GT/Stealth 25 08-01-2006 07:07 AM
AN to Inch conversion... anyone have one? TheSilentChamber Engineering/ Technical 1 04-14-2006 06:30 PM
got my new REAR END conversion done!! PIMPALA-SS '88 - '91 Civic | CRX | Wagon | Shuttlee 11 07-16-2005 05:28 PM
Drum to disk conversion - DONE Kocho Camry/Camry Hybrid/Vista 0 07-10-2003 12:18 PM
