Old 08-05-2003, 06:42 PM
knorsk knorsk is offline
a safe cheap way to adjust camber on accords
I have a friend who knows a friend who said that his friend said that there was a cheap way to adjust camber with 5th gen honda accords. Actually they didn't say that, but I was wondering if using shims would be a safe way of adjusting camber on a 2.25 inch drop. And if so, would it be dangerous? Or should I just spend tons of money on a camber kit?
There are two bolts where the suspension bolts to the frame. two shims would work nice but I'd rather know the possible problems before I am wrapped around a tree saying " I knew I should have bought that camber kit."
anyone ever pulled it off safely?
remember to keep it tucked between your legs (if ya wanna
pretend you are a woman)
You can find me at ImportRuiner.com
Old 08-08-2003, 06:48 PM
Or should I put it like this...what good is a technical forum if nobody knows anything technical.
Oh yeah, don't bother flamming this post unless you know the answer to the question. Then you can flame all you want and even fuck my sister!
Old 08-10-2003, 04:17 AM
1mugencrx 1mugencrx is offline
that's how i fixed my camber
if you're talking about using shims/washers to fix the rear camber on the accord, then that's perfectly fine. that's how most alignment shops fix the rear camber. they add washers and use two longer bolts (two each side) in the rear. the front is what you have to worry about. alignment shops will bend the spindles, but if they don't set your toe correctly, the car will feel like it has back-steer when you turn.
1992 Civic HB Si
B20 vtec w/: ported and polished B16A head, CTR LSD tranny, Exedy clutch, CTR cams, JE 10.8:1 compression pistons, Type R intake manifold, Portflow valve springs and retainers, AEM cam gears, AEM CAI, JDM Type R header, JG throttle body, AEM fuel press. reg, AEM fuel rail, Apex'i VAFC, ACCEL plug wires, Denso Iridium plugs, 5Zigen exhaust, etc.......
Lakers Rule!!!
is there official instructions on how to adjust camber? superuser General Discussion 3 07-04-2006 07:19 PM
How to adjust camber? Pavlo '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 02-19-2006 07:36 PM
Adjusting camber on 1994 K1500 Just Bob C/K 7 08-17-2004 07:34 AM
Should I adjust camber? Seany B Tires and Wheels 0 04-04-2004 04:40 PM
Neuspeed/koni sp3's yellows 5 way adjustable shocks greengsr2k Interior | Audio | Security 0 03-20-2004 01:31 PM
