Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 08-05-2003, 03:11 PM
daddys's Avatar
daddys daddys is offline
how low can they go
i was lookin at a 87 crx hf the other day and i was curious as to how low you can get them to go,,,i only have experience with the 4th gen civics suspension ,,,and i know the 3rd and 4th gen suspensions are different,,,anybody got a pic of a lowered 3rd gen civic or crx lowered?
Old 08-05-2003, 11:11 PM
ZcSi CRX's Avatar
ZcSi CRX ZcSi CRX is offline
no i don't have any pics . but its not hard to do. it just depends ho low you wanna go an how hard you want the car to ride an the rim tire you have on the rex.
Old 08-06-2003, 04:52 PM
nivek2002 nivek2002 is offline
Send a message via AIM to nivek2002 Send a message via Yahoo to nivek2002
low
well they are actually one of the easiest cars to moderatly lower. up front you just turn a not to lower it and out back a simple cut spring or proper lowering spring can be put in very easily. If you want extreme then you must cut a notch in it and move it a spline - there are websites out there that explain it, i can post links if you really want . And i suggest you do the shock lowering mod to get more travel when you lower, this is also explained more else where. Good luck, first gens are the bomb!
Old 08-06-2003, 11:11 PM
daddys's Avatar
ye could you post some sites with info about that ,,,thanks man
Old 08-07-2003, 12:24 AM
lowering
http://www.geocities.com/bishop132000/mods.html
specifically the Torsion bar and Strut Mod links are what u need , but that site has some nice info also. good luck
Old 11-24-2003, 03:24 PM
PSI RYDE PSI RYDE is offline
Send a message via AIM to PSI RYDE
Hello, in response to the question...you can lower 3G's about 4-4.5 inches and still maintain good ride quality. I had KYB's all around, Ground Control Coil Overs in the rear, Lightspeed front and rear sway bars, 24mm torsion bars, adjustable panhard rod, OPM or OMP front camber plates. I did one modification by threading more of the front shoch shafts and cutting off the excess threads in order to get more travel out of them. I had 16x7's and had no rubbing problems. But the torsion bars were a little stiff for daily driving. The car handled like it was on rails but even with the camber plates, I wore out 2 sets of tires in a matter of weeks! But I swapped out all of the road race parts and installed air cylinders and 17's...now my car can tuck tire and drag mud flaps when aired out. So, you can go as low as you want, contrary to popular belief!!!
How High Can They Go? jeev155 Lumina 3 11-04-2006 10:53 AM
how low can i go? Xplosive_Sheep Exterior | bodykits | Lighting 10 07-21-2002 05:22 AM
Koni RedS..How low can the spring/coilovers be? ReDCiViCPnoY '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 01-11-2002 06:28 PM
