Old 08-04-2003, 04:17 PM
maksum maksum is offline
Keyless Entry System on our van?
We just bought a 1998 Dodge Grand Caravan. The dealership only had a single key, and no remote keyless entry device. If the system is already installed in the van, I would like to buy the keychain devices and program them to our van. However, I don't even know if the system is there. Anyone know how I can find out?
It's pretty much loaded with most features you can think of, including an alarm system, so I wouldn't be surprised if it's there... I'm just not sure how to find out.
Thanks much in advance!
Old 08-04-2003, 05:10 PM
Ok, so I called a dealership and they simply looked up the VIN and they were able to tell me that it is indeed installed. They said they can give me a couple of the keychains for 44 bucks a pop! Man, that's expensive... so a couple more questions:
Is there a place online I can buy them for cheaper?
Can I program them myself? If so, how?
Thanks so much in advance.
Old 08-19-2003, 03:28 PM
Sport45 Sport45 is offline
http://www.keylessride.com/
Old 08-19-2003, 03:37 PM
Thanks. Comes to $40 from that site. $4 difference. That's a little better.
Old 01-22-2004, 06:14 PM
Bob Jensen Bob Jensen is offline
Re: Keyless Entry System on our van?
I just saw your question. I have bought several remotes on Ebay for under $6.00 check which one you need and look under auto,dodge,caravan,remote entry. that should work. or just do a search.
Bob J.
Old 01-22-2004, 08:11 PM
larryhe larryhe is offline
Not sure about 98 but on 97 the remote has to be programmed with a scan tool. If you had a remote that worked you could use it to program another one. Keep this in mind in case you loose one. Check at other dealerships in your area. You would be surprised at the difference in price I have received buy calling all dealers in my area. I bought one for my mother-in-law for 32 on her 97. The dealer may charge you for programming if you do not buy the remote form them.
Old 01-22-2004, 09:14 PM
I'm trying to get the information on programing for a 99 Caravan. I haven't had a chance to ask my friend if he has his manual but I will. I get conflicting answers from Dodge. Any help would be appreciated. Thanks Bob J.
Old 01-22-2004, 09:48 PM
Ghostman Ghostman is offline
Ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33691
Old 01-22-2004, 11:43 PM
Bob
I think I can find out the procedure for programing a remote but you will need one that is working already. Otherwise you need a scan tool with Dodge software. I will not have acess to info untill Monday or Tuesday.
Email me at [email protected].
Larry
Old 01-25-2004, 08:49 PM
[email protected] helinut222@msn.com is offline
I bought a RKE on E-Bay for 12 dollars. The dealer wanted 25 to program it. A friend had a service manual for a 97 Caravan. Its under power door locks. It took me two min to program it. Its like 6 paragraphs long and you have to hold the unlock button for so long while pressing the new RKE. I dont remember the exact way. If you need I can get the manual get you the exact way. Its easy I would have been mad to pay a dealer that money for a minute of time.
Old 01-27-2004, 12:13 AM
1999 Dodge Truck Grand Caravan FWD V6-231 3.8L VIN L SFI
Vehicle Level Accessories and Optional Equipment Keyless Entry Module Adjustments
The content of this article reflects the changes called out by TSB 26-09-99.
PROGRAMMING RKE MODULE
1. Using a functional key fob transmitter, unlock the vehicle and disarm the Vehicle Theft Security System.
2. Insert ignition key into the ignition switch. Turn the ignition switch to RUN position without starting engine.
3. Using a functional key fob transmitter, press and hold the UNLOCK button for a minimum four seconds (maximum ten seconds).
4. While holding UNLOCK button, and before ten seconds passes, press and release the PANIC button. A single chime will sound to verify that the RKE module is set to receive the new Vehicle Access Code(s).
5. Within 30 seconds of the chime, press and release the "LOCK" and "UNLOCK" buttons on the transmitter at the same time. Then press any one of the buttons. The BCM will sound an abbreviated chime to acknowledge that the programming of the transmitter has been completed and was successful.
6. Repeat step 6 for all transmitters that will be used with this vehicle (up to 4 total).
7. Programming mode will last for 30 seconds. To get out of programming mode sooner, turn the ignition OFF. A single chime will sound to verify that the RKE module will no longer accept additional Vehicle Access Code(s).
8. When Vehicle Access Code(s) programming is complete, turn the ignition switch to the OFF position and verify RKE system operation using each key fob. NOTE: Only the two key fob transmitters that have been programmed to the memory seat and mirror system will operate it. if any key fob is replaced, the memory seat and mirror module will require programming.
1998 Dodge Truck Grand Caravan FWD V6-229 3.8L VIN L MFI
3. Turn the ignition switch to RUN position without starting engine.
4. Using a functional key fob transmitter, press and hold the UNLOCK button for a minimum four seconds (maximum ten seconds ).
5. While holding UNLOCK button, and before ten seconds passes, press and release the PANIC button. A single chime will sound to verify that the RKE module is set to receive the new Vehicle Access Code(s).
6. Within 30 seconds of the chime, press any button on each new key fob transmitter. After 30 seconds or when ignition switch is turned OFF, the RKE module will end the programming mode. A single chime will sound to verify that the RKE module will no longer receive additional Vehicle Access Code(s).
7. When Vehicle Access Code(s) programming is complete, turn Ignition Switch to the OFF position and verify RKE system operation using each key fob. NOTE: Only the primary (first two) key fob transmitters will operate the memory seat and mirror systems. If a primary key fob is being replaced, the memory seat and mirror module will require programming.
Old 08-13-2005, 01:47 PM
kb9ewg kb9ewg is offline
Send a message via Yahoo to kb9ewg
I recently purchased a 1989 Plymouth Voayger LE in very good condition was well maintained by previous owner I am wondering if this year model had the keyless entry was availeble and if so how I would determin if my van indeed has keyless entry or not I tried http://www.keylessride.com/ and they do not hande my year any info would be helpful thank you
Old 08-13-2005, 01:52 PM
slacker_53's Avatar
slacker_53 slacker_53 is offline
Re: Re: Keyless Entry System on our van?
Call your dealer with the VIN#, they will be able to tell you if your van is so equipped. You can pick up transmitters from ebay for much less than at your dealer and you can get programming information on this forum for your model Caravan.
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
Nissan Sentra keyless entry module location serge_saati General Discussion 2 06-26-2010 10:03 PM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
Aftermarket Keyless Entry System messed up the TheftLock/ignition system 97chevy_lumina General Discussion 0 08-04-2003 05:48 PM
97 olds Help Keyless entry system wjt_73 General Discussion 0 06-18-2002 07:17 PM
