Old 08-01-2003, 09:38 PM
levi_k levi_k is offline
honda motor
in 1989 what motors could have come out in a honda civic hatchback si, it says 16valve and DOHC on it, he says its 2.3 or something above 2.0 but i think it could only be a 1.6. it would be cool if it were higher, either way I could use some suggestions on mods, cam, intake, exhaust, turbo/supercharger, cold/ram air, fuel system, anything to make it better. thanks.
Old 08-01-2003, 09:53 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
look on the block for an engine code and let us know what it says ... we should be able to tell you what motor it is.
Your car definitley has an engine swap .. no stock 89 civic si came with a DOHC motor.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 08-01-2003, 10:00 PM
i believe it is
D16A6
2602101
thanks
Old 08-01-2003, 10:14 PM
<[4gen91CvcLX]>'s Avatar
<[4gen91CvcLX]> <[4gen91CvcLX]> is offline
Send a message via AIM to <[4gen91CvcLX]>
that's the stock 1.6L Si engine...but it's probably not DOHC....
__________________________________
1997 Honda Civic CX Hatch
Old 08-01-2003, 10:18 PM
whats the difference between a DOCH and an SOCH? i'm pretty new to imports and i'm trying to figure out if its worth fixing up this honda, actually it's in good shape and has really low mileage(less than 100,000 i think), just trying to figure out what I'm working with first
Old 08-01-2003, 10:20 PM
DOHC = Dual Over Head Cam
SOHC = Single Over Head Cam
Old 08-01-2003, 10:24 PM
i'm assuming you can get more power out of a dual cam setup? and whats a good cam to upgrade too, or does changing the cam usually mean you have to start changing out the heads and intake right away?
Old 08-01-2003, 10:38 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
The only way to get to a DOHC setup is to change either the head or the whole motor. The easiest way to get into that is the ZC motor. Putting a DOHC head on that motor would be a serious pain. However, you can do several different things like getting a SOHC V-tec head, a SOHC V-tec motor, or a B-Series motor. This has been hotly discussed on this forum, and you can find oodles of threads where this issue has been debated back and forth to no resolution.
However, if you want to do it the right way, it's a B-series motor that you want. The B20, B16, and B18 are all excellent motors and give you a good starting point for some serious power. If you want to put on a V-tec head, I have one I can hook you up with, that has a really cool ZEX cam in it. If you want to do a whole V-tec SOHC motor, I can get ahold of one of those for you as well. However, I would say to do a B16 or B20 for something that is totally driveable, a stable foundation to add to, and something that not everyone has... Just my $0.02. Do a search for ZC or B16 and you'll see where it has been discussed...
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Could I take a 1999 Honda Civic Motor and put it into a 1994 honda prelude? jluzzrebellion General Discussion 2 02-09-2011 11:40 PM
Honda motor, parts, other honda stuff. pimprolla112 Cars/Parts for Sale/Exchange 0 01-10-2006 12:13 AM
honda motors online... diegoaccord Engineering/ Technical 2 02-16-2002 02:27 AM
