Old 08-01-2003, 07:33 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Angry wobbly ride
When I step on the brakes, it makes a rattling noise and it vibrates real bad up front. Also, when I go over bumps, the front suspension rattles. Anyone know whats causing this? Its a really wobbly ride and its starting to scare me. I have to get it inspected in a week so im gonna have my mechanic check it out then but id like to know before hand if any of you can help me out.
Old 08-01-2003, 07:59 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: wobbly ride
It could be bad rotors or bad joints. Does this only happens when you brake? Or when you drive?
Old 08-01-2003, 08:04 PM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
my car did this BAD too...
on cars our age it is common for the seal around the piston in the caliper to start going out, and this can cause it to stick, making the brakes apply uneven pressure between the driver and passenger side.. so i had to replace my calipers because of this...
also, i had my rotors machined and put in new pads.
i had a shop do it, and the total bill for labor, new calipers (not remanufactured), pads, and rotor turning was 650 from a honda/acura specific shop.
Old 08-01-2003, 08:06 PM
It does it really bad when braking but the pedal doesnt go up and down so it shouldnt be warped rotors or anything. That could be what it is though DarkImportGrey, thanks for your input. I also think Im gonna need new balljoints and possibly control arms. Also, to boot, im way out of allignment... great.
Old 08-01-2003, 09:15 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Yeah, I'm in the same situation. I've got all new ball joints (upper and lower), tierod ends, struts, and an energy suspension bushing kit (while I got this stuff apart I might as well replace the bushings too right?) for a grand total somewhere north of $700, just for the parts!
I love my car!
I love my car!
I love my car!
Too bad it won't start...
Old 08-01-2003, 09:51 PM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
This definitely sounds like warped rotors. I'd also be checking the tension on the bolts on your calipers, just in case. The only other thing worth checking is your ball joints as they are constantly under load - more so when you get on the brakes.
As for the rattling... it's a Civic
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 08-01-2003, 10:27 PM
blacksheep blacksheep is offline
Send a message via Yahoo to blacksheep
i had the same kinda problem but it wasnt the rotors or ball joints, the inner tie rod ends were bad, sucked cause it took me forever to figure it out
it better get me to wyoming
Old 08-02-2003, 04:16 PM
I assume all that took care of the problem? Or atleast I hope so.
Old 08-02-2003, 06:23 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
my car does this as well, i'm waitin on money for new calipers, my cars strut also rattles over bumps and shit, need 2 replace it, goto the local performance shop and get a new KYB GR-2
Old 08-02-2003, 06:25 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
someone near you is selling new ones.
http://www.automotiveforums.com/vbul...21#post1116821
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 08-02-2003, 06:29 PM
HONDABOND HONDABOND is offline
My ride did the same thing when my rotors were toast. is it your steering whell that shakes or is it the car?
White folk eat noodles too.
Old 08-02-2003, 10:09 PM
johnb16a2's Avatar
originally quoted by 91civichatch2571:
Well actually no, it didn't fix the problem (did I mention the parts are currently sitting in my room?).
Anyway, I also hope all that stuff fixes the ride. Good luck with your car.
Old 08-03-2003, 05:53 AM
Its my steering wheel that shakes.
Thank you, you too
Old 08-07-2003, 04:13 PM
origamiguru origamiguru is offline
Klunky Clunk.
I replaced my pads and rotors on my civic, that made quite an improvement, stopped all my wheel shake on decelleration. although I still have a funny 'klunk' sound that seems to come from the rear of my car, sounds like a body rolling around in the back. Dunno what it is yet. any suggestions?
Thanks all!
-Adam.
Old 08-07-2003, 04:48 PM
Well, I figured out what was causing a lot of the shaking and shit. My car was way out of allignment so I fixed that the best I could. Not so shaky anymore when braking. Also though and this is where the real problem lays, my steering rod (the part that connects to both wheels to move it side to side when you turn, also with the tie rods on the ends). It had a lot of play in it causing the whole front axle to vibrate occasionally. So right now im replacing that and its a pain in the ass. New calipers also helped a bit. New suspension goes on tomorrow though
95 mercury tracer wobbles when i give it gas danz409 Tracer 6 02-28-2010 01:34 PM
Bad wobble, 1999 corolla VE Dale_p Corolla/Matrix/Voltz 4 12-30-2009 10:57 AM
03 Ride Height Problem - 03 Silverado 1500 z71, 5.3L tallroach85 Silverado 2 04-03-2009 10:30 AM
Wobbling front end das_kuppler Ram Pickup | Ram SRT10 3 03-07-2009 03:17 PM
