Old 07-31-2003, 08:42 AM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
crossthreading
ok when i was bolting the engine up to the stand, i aparently crossthreaded one of the holes where the tranny would bolt up to the block. i'm putting it all together now so i'm wondering should i go without that one bolt and make sure the rest are torqued down or use it for now? also, how do i fix this?
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 07-31-2003, 10:41 AM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
take it to some one who has a tap... they can maybe straighten out the threads for you if it isn't too bad...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 07-31-2003, 10:52 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
it should be easy to tap it while its on the stand...just go ahead and take care of it.... better to take a lil time now then alot of time later..
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 07-31-2003, 10:59 AM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Load that sucker up and take it to a machine shop. It's already out of the car, and they can fix the damage in about 30 seconds.
Unless you have a tap, in which case you can spend five minutes of your own time.
You'll have to get the bolt out though, to get it off of the stand and into your trunk or the back of a pickup. If you use a big breaker bar or a big ratchet with a cheater, you can manage to break of the head of the bolt, or it'll come out with a big wad of aluminum stuck in the threads...either way, they'll fix that at the machine shop. You've got nothing to lose, at this point.
Definitely take care of it before you put it back in your ride. If you just leave it out, there'll be vibrations, and the other bolts will get loose, and it'll become a headache that won't go away.
I bet the machine shop will charge you 10 bucks and send you on your way.
Flunky
PS-Hmm...sounds like you've already got the bolt out. Tap that sucker!
Old 08-01-2003, 09:50 AM
Jay eS Iye's Avatar
well glad i didn't have this in the car yet (i had alot of difficulty dropping it back into my engine bay for some reason, guess i just need someone to help meiwth it)... now will i have to take the bell housing back off or can i do it with it on?
Old 08-01-2003, 06:56 PM
AF Premium User
I don't get it. Is it bolted to an engine stand, or is it bolted to the transmission already?
Is the bolt still in there? Have you taken the crossthreaded bolt out yet? You've lost me.
Flunky
Old 08-01-2003, 07:11 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yea this is all backwards, if the bolt is fully out then just run a tap in there to try and save the threads, if not a machine shop is the way to go.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-02-2003, 12:20 AM
Jay eS Iye's Avatar
ok lemme try this again. when i was putting the engine onto the stand, i must have messed up the threads and just didn't realize it at first. i took it back off and attached it to the hoist and put on the bell housing and realized when i tried to put the bolt in that it was crossthreaded. so i removed the bolt and attached the rest of them. so right now i have the engine side bolt, and 3 out of hte 4 tranny bolts holding it on. the one that is messed up is the top front bolt. can i tap it while the bell housing is still on and the engine is held up by the hoist? or can i even do it when the engine is in the car? i just got to get this hoist back ASAP
Old 08-02-2003, 01:28 AM
crx hf crx hf is offline
Just curious what kind of engine is it?
Old 08-02-2003, 01:50 AM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
drill it out and tap it.
Old 08-02-2003, 10:12 AM
Jay eS Iye's Avatar
its a d16a6... and sicne i have yet to get much input on if i can do ith with the bell housing on or in the car, i'm just gonna try it, b/c i need this back in.
crossthreaded and striped out spark plug lilredhondacivic Automotive News Desk 3 05-09-2004 01:37 AM
90' V6 Camry spark plug crossthreaded hollbaq Camry/Camry Hybrid/Vista 6 04-01-2004 07:57 PM
Crossthreaded Fuel Filter bolt. CutlassLover Monte Carlo 0 10-09-2003 11:32 AM
crossthreaded spark plugs crossthread '88 - '91 Civic | CRX | Wagon | Shuttlee 6 07-20-2003 02:59 AM
