Old 07-30-2003, 10:45 PM
adg2dln12 adg2dln12 is offline
Send a message via AIM to adg2dln12
Lightbulb Fuel pump relay location 95 GT
Does anyoen know where the fuel pump relay is located on the 1995 ford mustang gt? If you do please reply, thank you
Old 07-31-2003, 01:13 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
If its the same as a Fox Stang and I think it prob is. Its under the drives seat.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 07-31-2003, 02:08 AM
umm not sure
what does it look like?
Old 07-31-2003, 07:36 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: umm not sure
On my car it's green and about one cubic inch in size.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 07-31-2003, 04:11 PM
94svt5.0's Avatar
94svt5.0 94svt5.0 is offline
On 94 and newr stangs the fuel pump relay, low speed, high speed fan relay and ECM relay are all contained in a sealed box known as the CCRM (constant control relay module) It is located between the overflow bottle and the radiator. You have to replace the whole thing($120) or if your cheap, drill the pop rivets out, pop open the box and solder a new relay in.
More photos and Info/website!
1994 Cobra
-off road h-pipe
-superchips power chips
-mac cold air induction
-BBK aluminum underdrive pullies
-pro-m 75mm bullet MAF
-18" konig wheels with nitto 555 zr tires
-Ford Racing 65mm throttlebody
-Ford Racing king cobra clutch
-Ford Racing 3:73 Gears
-Ford Racing Aluminum driveshaft
-Bullit suspension/ springs,shocks,struts
-Aubrun HD limited slip Diff.
2002 subaru Impreza RS
- stock
1989 Toyota pickup 4x4
-K&N
Old 07-31-2003, 04:23 PM
I still havent figured it out
Im not all that smart but what you just told me I dont know I cant seem to find it
Old 07-31-2003, 04:56 PM
94svt5.0's Avatar
The CCRM is attached to the bracket the holds the radiator overflow bottle. If you look behind the bottle, between it and the radiator. The ccrm is a square shaped box about 7"x 6" and about 2" thick. It has a big wire harness plugging into to it, held on with a small bolt. The CCRM looks very much like the cars computer, which is in the kick panel. Let me know if this helps. What makes you suspect the fuel pump relay being bad?
1994 Cobra
-off road h-pipe
- stock
-K&N
Old 07-31-2003, 06:08 PM
is the relay inside it??????????
I have been messing with that box, is the relay located inside the box, the Ford Company told me the relay is $15.00 dollars, the reason i suspect the relay not being any good is that I drove the car the I think I shorted the wire by touching it to something the fuel pump doesnt turn on anymore.
Old 08-01-2003, 02:44 PM
94svt5.0's Avatar
Yup, he fuel pump relay is supposed to be inside the box, but there are several different relays inside the box. Not sure how you pinpoint which one is the pump.
Did you check all your fuses first to see if one blew? fuses under the hood and the ones under dash?
1994 Cobra
-off road h-pipe
- stock
-K&N
Old 08-01-2003, 06:27 PM
I checked them all
All the ones under the dash work but the one of them under the hood doesnt its a 10 volt one but i cant figure why It isnt working I switched it out and everything
Fuel pump our relay Apfire8 Villager 1 11-10-2010 06:08 PM
fuel pump relay location for 95 626 flintstone 626/Capella/Capella Wagon 4 06-19-2005 11:55 AM
Where is fuel pump relay located??? 67Stang Thunderbird 2 07-17-2003 08:24 PM
Fuel Pump Relay Location WhateverMan Millenia/Xedos 9 0 07-08-2003 04:47 AM
Fuel Pump Relay location on '93 525? rpfeiler 5 Series 2 01-16-2003 03:48 AM
