Old 07-30-2003, 10:44 PM
jackacc's Avatar
jackacc jackacc is offline
easy question
I havent even looked at this yet....
My antenna was pretty much rusted and would not collapse when I go to the car wash and such and it just bent and broke at the base. I ordered another one but do I have to run the whole cable to the radio? Or can I just splice it?
Or can I seperate the top black part that screws into the car (that holds the metal part of the antenna) and reattach it to the line that is already ran to the radio? Sorry...stupid question but I figure someone knows and can tell me b4 I look at it...
Thanks
Old 07-30-2003, 10:48 PM
blacksheep blacksheep is offline
Send a message via Yahoo to blacksheep
i duno but i dont have an attenna no more cause i pulled it out on accident, Knowing that a cable didnt come out with it that maybe there would be a way to connect it witout having to run a new cable
it better get me to wyoming
Old 07-30-2003, 10:49 PM
CivicWarrior CivicWarrior is offline
Send a message via AIM to CivicWarrior
i know u can splice the line but u wont get as good quality... u should jus replace the line its fairly easy... i cant help u on the other part.... sorry... hope i was in some way helpful
I rip cats quick..i mean..i'll tear up ya whole style n'..
..i'm the biggest thing to hit the streets since racial profilin
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
it should seperate at the base of the ant.
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 07-30-2003, 10:54 PM
GTA's Avatar
GTA GTA is offline
Whee..
unplug old anntena plug. attach strong fishing line or string of some sort (make sure its really long). Take off old anntena and pull out wire until you see end with string or line attached. Untie string/line and tie to new anntena wire. Pull string to bring new anntena wire to where its supposed to go.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 07-30-2003, 11:05 PM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
TRUST ME....
You don't wanna have to try and fish the cable down through the A-pillar. Holy shit....what a pain in the ass. It seriously took me about 4hrs to get mine down the hole properly.
Its damn near impossible, becaust the sunroof drain is also in the A-pillar, and the hole where the wire goes under the dash is all up behind the fresh air duct and a/c plumbing. Absolutely impossible to get to, unless you have hands the size of a small child.
Im not sure if you can splice those cables effectively. But if you do it like gta said, it should not be more than a 15 minute job.
Good luck man
There's nary an animal alive that can outrun a greased Scotsman!
Old 07-30-2003, 11:09 PM
<[4gen91CvcLX]>'s Avatar
<[4gen91CvcLX]> <[4gen91CvcLX]> is offline
Send a message via AIM to <[4gen91CvcLX]>
if u do what GTA said, which i highly recommend if u run new wire, try going to an Angler's shop...or if theres one around a Bass Pro Shop, and get heavy duty off shore fishing line..it's just as expensive as regular line, but it's for deep sea fishing so it's got like a 50 lb. test...
__________________________________
1997 Honda Civic CX Hatch
Old 07-31-2003, 12:24 AM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
i just wraped mine with tape and pulled it through, took like 15 min for the whole install
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 07-31-2003, 02:11 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
That wire is just a normal coax wire (cable tv line), so you can splice it, but you really should run the new wire down to the radio. Yes, it can be a pain, I had that tube for that the antenna slides down into get stuck when I pulled my old one out, and I have a sun roof, so now I have 2 of those tubes, a wire, and the sunroof drain all in that one space.
Old 07-31-2003, 02:16 PM
jackacc's Avatar
It actually still works pretty good...considering the antenna is snapped off... I still get Howard in the morning on the way to work so I am happy...I rarely listen to the radio anyway...always a CD...But I need to replace it.. I may try to splice it first and if that does not help...I'll run the whole thing.
Easy question, just need the "slang" name CivicSpoon Engineering/ Technical 5 03-07-2003 03:06 PM
easy question 00 denali BIG SMOOTHIE Yukon 0 02-10-2003 04:36 PM
Ok, quick easy question JRuner1 Car Audio 0 04-27-2002 12:50 PM
I really need help about 350Z!! its really easy questions.... dan709 Nissan 350Z/370Z | Infiniti G35/G37 Coupe 2 02-27-2002 02:32 AM
Confused Newb, pry easy questions for you guys... Cyphatic Lancer 15 11-19-2001 11:10 AM
