Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 11-24-2001, 07:29 PM
greekman's Avatar
greekman greekman is offline
outer boot replacement questions
finally got to putting my new boots on. i followed the instructions from the previous thread i posted, but i'm lost. how do i get the boots on? i have the axle disconnected from the rotors. the axle is out of the tranny on both sides. the axle shaft slides to a point, but won't come out of the tranny. where do i go from here? i've included some pics of what's going on so if you need more pics let me know. thanks in advance.
93.5 G20
Life is like a shit sandwich. The more bread you have, the less shit you taste. So go out and get your bread!
Old 11-25-2001, 01:06 AM
P10DET's Avatar
P10DET P10DET is offline
Re: outer boot replacement questions
Sounds like you're talking about the driver's side halfshaft. It has a circlip that makes it a bit difficult to remove and install. I usually just remove it with on good yank.
However, you can't do that now that you've gotten to this point. It must be pried out. It helps if you rotate the shaft while prying it out. You might have to ease off the prying pressure at some points as you rotate the shaft so it can re-center.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 11-25-2001, 12:00 PM
greekman's Avatar
geo. i didn't type the right thing. my bad. the axles are out of the rotors. we're trying to pull them out of the tranny, but they won't come out. do you just pull hard? what is a circlip? here's a link to pics that i took last night http://photos.yahoo.com/greekdeno
93.5 G20
Old 11-25-2001, 01:02 PM
greekman's Avatar
geo, i pmed you but i don't know if you've read it yet. if not-i want to call you to get some help with this. pm me your # if that is okay. thanks
93.5 G20
Old 11-25-2001, 01:08 PM
P10DET's Avatar
No, you typed it OK. I think you are talking about removing the halfshaft from the driver's side of the gearbox. A circlip is a circular clip that in this case keeps the halfshaft from falling out of the gearbox.
You shouldn't just yank hard at this point becaue the clip has already slipped down in the groove cut into the end of the halfshaft. You'll have to pry it out while rotating the halfshaft slightly.
George Roffe
Houston, Texas USA
00 328i
Old 11-28-2001, 12:19 AM
greekman's Avatar
much thanks goes out to george. he helped me emensely (sp?) with this repair. geo- the rings that we asked you about are inside-they're just hard to find b/c they're small in diameter and their's covered in grease. all in all it took about 9 hours from rolling in the garage to rolling out. the thing that took hella long was the fact that i only bought the plastic boots, not the whole axle. had we replaced the axles it wouldn't have taken a lot less time. if anyone has questions about doing this to their car i am more than willing to help, but geo can probably help you more. once again thank you very much george.
93.5 G20
Old 11-28-2001, 10:28 AM
GtRider GtRider is offline
Send a message via AIM to GtRider
how much did you paid for the rubber boots?
and where did you get them from?
was the installation of the boots hard to install?
did you had to repake the boot with grease?
both of my boots are torn,
should i buy 2 new boots or should i just go get an axle?
i can get an axle from a parts store for 60.00 bucks thats with the core.
94 G20t
Old 11-28-2001, 01:11 PM
greekman's Avatar
i paid $25 for the boots. got them from napa. they came w/ grease, and i bought more grease. to pack it basically you put one side of the boot against the cv joint so no grease leaks out and then you slop that stuff in. we spread it from the axle shaft back toward the cv joint. i highly recommend wearing some surgical gloves when doing this (or any other dirty work on your car). you take those things off and your hands are nice and clean.
if you have the resources, time, and patience i would replace just the boots. if i had to do it over i would replace the whole axle. it'll take a lot less time, energy to replace the axles.
93.5 G20
Replace outer boot 1990 dodge grand caravan aleksandr Caravan | Voyager 0 11-08-2008 01:38 PM
94 caprice rear outer bearing replacement 4evrbad Caprice 3 07-21-2008 10:31 PM
Outer CV boot replacement Midnight_Fenrir Toronado Trofeo 1 08-14-2007 11:12 AM
e36 outer ball joint question hoodmeister 3 Series 1 08-10-2005 06:16 PM
Question about outer CV boot replacement Type_Race Integra 2 04-12-2004 01:53 PM
