Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 08-06-2005, 02:38 PM
hoodmeister hoodmeister is offline
e36 outer ball joint question
I just had a maryland inspection to title and register my son's 95 318i and everything passed except the front ball joints. mechanic said there was too much play. i read on the internet that the ball joint is unique as it has rubber around it, causing the frequent mis-diagnosis that they are bad. I raised the front end and yanked on the wheel and they seem tight. i also used a large screwdriver to pry on them and did get some movement, but it feels like tight rubbber, not looseness or play. how do i properly check them and how do i convince the mechanic that they are good, assuming they are? no idea when or if they were replaced.
thanks!
Steve, 1995 BMW 318i 176,000 miles
Old 08-10-2005, 06:16 PM
Bear Bear is offline
Ball Joints
Find an independent tech in your area that specializes in BMWs and tell him your problem. The tech should be able to give you a professional opinion and if all is well pay him to put it in writing.
