Help! Starting Problems
Hi there,I am new to these boards but now I have a problem and look to you guys to assist me.I just purchased my second 1990 Civic Si (totaled my last one) I've had this one for a week and now it has problems starting. The car will crank fine,but it just wont start.Anyone had this problem before?Any suggestions on what the cause could be would be greatly appreciated.
I thank you in advance for your assistance. Last edited by tterb85; 07-30-2003 at 07:44 PM. |
It could be a few things, im leaning toward main relay (as many ppl will). Does it start ever? Cuz if its the main relay itll start when its cooler outside but wont when its hot. Try banging on the underside of ur dash when its cranking to, worked for me, if that does work then its probly the main relay, but the real experts will probly want more info.
Born 2/19/85: Thats right ladies, the BMan is Legal!! ;-) Totallin My 89 CRX Si: +$2700 Buyin It Back From Insurance: -$50 Buying a 90 CRX Si: -$2200 Gettin to start over with more money and knowing i screwed insurance w/out trying: Priceless It doesn't matter if you win by an inch or.........wait, thats been said already. On the road of life there are passengers and......no, thats been done too. Dang, all the good sayings have already been said, ohwell. -BMan original |
Thanks for your advice,I tried starting it,still no go.I've had the car for a week and this morning when I was leaving for work,it just wouldnt start.It wasnt really hot outside,it was fairly cool. I really want to try and figure this out otherwise,I'll need to get rid of the car.Any more ideas would be greatly apreciated
Well just yesterday my car wouldnt start.All i did was replace the ditributor cap and it started up.Check your rotor/cap.Are you getting any spark.
Probably main relay or igniter.
-1994 Civic coupe DX |
i would say the main relay, bought mine for 17 bucks at napa autoparts and replaced it my self
it better get me to wyoming |
Thanks guys for all your suggestions,got the car towed to garage,I always hate that sight of your car being towed away into the distance.I guess I'll find out what the problem is. Thank you for your time
shoulda checked the fuel pump fuse too. i made the mistake of not doing that once and it cost me an $80 tow for a fucking fuse.
![]() - Eibach Sportline Springs - KYB GR2 Gas Shocks - The usual clear lenses/hyperwhite bulb Next: Front/Rear lower tie and upper strut bars |
Gotta have three things: spark, fuel, and compression.
Check spark first, it's the easiest. Then loosen the fitting at the fuel filter and see if fuel sprays out. If you got spark and fuel, take out a spark plug, screw in a compression tester and check that. Use the scientific method. NOT the process of elimination! Flunky |
