Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-29-2003, 05:03 PM
PreludeMOFO PreludeMOFO is offline
Question Turbo Stage Questions
Im along way away from affording any form of a turbocharger for my 94 Prelude vtec, but what my question is is whats the diference between say a stage one and a stage four turbocharger? What do the stages represent?
Thx for the Help
Old 07-29-2003, 05:12 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
In the simplest terms I can think of, a stage one turbo will spool a lot faster than a stage four. Lower stage turbos tend to be smaller while higher stage turbos tend to be bigger.
Old 07-29-2003, 05:14 PM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
There is no such thing as stages, they are simply something invented by a company in order to market progressive turbocharger kits. A stage one kit can be anything, as there is no such thing as a stage one turbo. Basically the stage 1 will be the lowest boost, lowest power kit. the higher stages will be higher power. But technically there is no such thing as a stage.
The difference between stages will vary between companies, but generaly a stage one will be a non intercooled low boost setup. Stage two will incorpoate some sort of intercooler, and a slightly higher boost. Stages higher than this will start to include strenghtened internals, and driveline parts, in order to run higher boost settings.
While some companies use different turbos for each stage some use the same one and change the peripherals with each progressive stage. Like I said, it can vary as there is no set "stage".
Beer tastes better upside down.
Old 07-30-2003, 08:06 AM
integragsr98 integragsr98 is offline
Don't worry bout the stages...it's bs...just look whats included in the kit.
xtremetuners.com
Old 07-30-2003, 06:48 PM
Polygon's Avatar
The Red Baron
True, it is just a marketing ploy.
Old 07-30-2003, 11:44 PM
ok thx of rhte help!
1996 Neon ATX HRC Turbo Stage 2 Sedan JDMBluebirdDorifto 1st Gen 95-99 0 09-30-2004 08:38 PM
turbo sizing question sushi Forced Induction 1 04-15-2002 11:50 AM
HKS turbo pricing questions. Inspire95 Forced Induction 2 02-09-2002 12:01 AM
Turbo/Supercharger question MBTN Engineering/ Technical 4 01-25-2002 10:06 AM
