Old 07-29-2003, 01:16 PM
WhitePony WhitePony is offline
Send a message via AIM to WhitePony
Question 7.5 to 8.8
I have a 98 V6 with the stock 7.5 rearend. Is it worth it to go for the 8.8? I have read/heard that the T-bird is a close match for the rearend in the mustangs, but most of what i hear is for the earlier platforms. Does anyone know if this will work on my 98?
BTW if anyone is looking into a stang stay away from the 98's. Its a pain in the a$$ to get mods. They all range in years from 95-97 then jump to 99-02. The 98 ALWAYS require some kind of special "tweak" to make the aftermarket parts work. I guess i should have done my homework before jumping into the world of stangs.
Any information on this would be greatly appreciated.
Thanks
BTW (again), whats up with these one-wheel burnouts? What kind of Diff is back there? Open, LSD, what the hell. Again i guess this is another area where homework would have helped out.....
BBK Cold Air, MAC Underdrive Pulleys, and a few cosmetic Add-ons.
Old 07-29-2003, 03:09 PM
JE123's Avatar
JE123 JE123 is offline
Re: 7.5 to 8.8
Thanks
I thought everybody like the one-wheel burnouts. j/k You can t-lok to avoid this.
A 8.8 is a much stronger rear end than a 7.5. The actual rear end itself is larger, which allows the parts inside to be bigger(carrier, differential, gears), thus making them stronger. Many people swap to 8.8 rear ends because it can be more economical to buy a whole 8.8, or a used 8.8 than replacing, and installing parts on a 7.5. The axles and brakes are interchangeable between the 7.5 and 8.8 axles as well providing the differential in the 8.8 is not made for 31spline or larger axles(stock 7.5 and 8.8 is 28spline).
I got that info from http://www.3.8mustang.com/forum/showthread.php?t=29525
I'm not sure if a T-birds will fit right.
-Joshua
Old 07-29-2003, 03:26 PM
Smile Re: to 7.5 to 8.8 reply
Guess ill just have to do some more homework. Im not sure what spline my axle is but im sure someone knows and if i continue scowering the net i will eventually run into that person(s). Thanks for the info. Ill try to keep everyone posted, just incase someone else has questions about the rearend parts.
And by t-lok i assume you mean Traction Lok Diff.
here i go...
Wish me luck...
Old 07-29-2003, 05:10 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Why with a V-6 do you need an 8.8? Unless you add some serious power to that V-6 it is really not needed. 7.5 are not as weak as you think. My 83 GT had a stock 7.5 rear-end. That car was dynoed at 348hp and 412 torque and it still had the 7.5 and didnt have any problems. Just trying to save you some cash you could spend on other mods.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 07-29-2003, 09:27 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Agreed!
The reason you car is "peg legging" it is cause, V6's don't have limited slip rear diff's.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 07-30-2003, 01:35 AM
76_cobra's Avatar
76_cobra 76_cobra is offline
I find that hard to believe that that rear held 348hp My friend had an 85 with the 7.5 and he blew the rear and all he had done to it was an exhaust, and my friend's sister blew two 7.5's before she got rid of the car I think it was an 86 or 87, I have heard that a lot of stock 80's mustangs blew their 7.5 rear ends.
Are you gonna bark all day little doggie....or are you gonna bite?
Hell of a thing, killin' a man. Take away all he's got and all he's ever gonna have.
Yeah, well, I guess he had it comin'.
We all got it comin', kid.
Old 07-30-2003, 03:04 AM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
right, but all the same, the ultimate issue is this fellow's v6. money and time could be better spent elsewhere.
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 07-30-2003, 06:58 AM
HiFlow5 0's Avatar
Stanger
Same can be said the other way. I have seen 7.5" rears in turbo 4's putting out some good power hold up fine. I still don't think it's necessary to replace the rear in his car at this point. there are other areas to improve upon first.
-2013 Ford Flex
-1999 Ford F150
Old 07-30-2003, 08:18 AM
Thanks to everyone, for all the feedback. Helping me make this decision. So now its off to search the web for some 3.73's. Does anyone have a good Website with them. I found a few and they all range around $120-$180. Depending on the name of the site is really all the difference i could see.
Also i guess i should find an LSD... to cure the burnout problem.
Again thanks to everyone. Ill keep you posted on what i get and where.
Old 07-31-2003, 01:26 AM
GTStang's Avatar
Stang Guy
The only people to call about Rear-end parts is Reider Racing(Rears and Gears). Theyll hook you up and thier knowledge is un-touchable.
If you wanted to be cheap Early 80's 5.0 Mustangs had 7.5's wit LSD I believe(Some1 correct me if Im wrong). You could yank one out of there but it might need a rebuild.
Old 07-31-2003, 09:21 AM
Then its off to the junk yard i go.
Thanks
Old 08-02-2003, 05:38 PM
spectorv spectorv is offline
you dont have to get a new rear they make gears for the 7.5 rear, but if you can get your hands on a nice 8.8 with 3.73 gears from a Tbird supercoupe then i would do taht if its in good shape that is. your pre 99 stang has POS gears 2.73 ratio.....i used to have a 97, i put in 3.73 and shaved a half second exactly from my quarter mile times so its definatly worth the swap. you can do an 8.8 in your drive way in an evening with the proper tools.
Old 08-02-2003, 07:10 PM
GTStang's Avatar
Stang Guy
A tbird rear-end mouting holes need to be relocated and if you dont your pinion angle will suck and ruin your times.
Old 08-03-2003, 10:32 AM
Damn.
is it a 7.5 or a 8.5??? gorgepr Suspension and Drivetrain 2 11-13-2008 07:34 PM
can you install 8.5" 10 bolt ring gear on a 7.5 inch 10 bolt carrier? Need Help FAST bjrjr16 Problem Diagnosis 3 08-29-2007 10:05 PM
5.7 vs 4.8 97sle Sierra 0 08-04-2006 03:44 PM
FT: Brand New 17 x 7.5 30mm Chrome rim for 18 x 8 350z rim used or new. YoungRick Classifieds 0 01-28-2006 05:09 PM
7.5 or 8.5 wheels on the rear bmw_jeff_325i 3 Series 1 03-24-2002 11:39 PM
