Old 07-28-2003, 02:57 PM
toronto pimp toronto pimp is offline
installing bushings
Energy Suspension bushings are said to be 'easy to put in'. I know if I got stock Honda bushings I would need a press, but people say you don't need one to put in energy ones. Is there any truth to this? And if so, how is it done without a press?
- Eibach Sportline Springs
- KYB GR2 Gas Shocks
- The usual clear lenses/hyperwhite bulb
Next: Front/Rear lower tie and upper strut bars
Old 07-28-2003, 10:12 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
you still need a press to get the stock bushings out, but you can put the new bushings in without a press. just put the black center bushing in first (if that particular hole is supposed to have one) and then the two outer bushings. they fit snug, but its not too hard to put them in. after that just put the metal shaft in the middle, and then tap it down with a hammer.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 07-29-2003, 10:21 AM
That's great news because that means I only need to pay to get the one side done. I got the rear control arm bushing kit from Energy Suspension thinking that it had the shock bushings in it. My mechanic cut off the left said and then realized that those bushings weren't in the box so he used one of them as a temporary bushing just so that I could drive the car. That means when my REAL bushings come in on Wednesday, I can take the left one out and put the correct bushing in. I still need to take the car in to get the right side done because it needs to be torched off.
96 Intrepid rack and pinion steering mount bushings ksroadking Intrepid 2 02-27-2014 06:39 AM
Help for Control arm bushings mikev46614 Rendezvous 2 10-01-2010 06:42 PM
97 Intrepid 3.3 Sub Frame Bushings and Mounts Gabriel T. Intrepid 1 07-03-2010 05:13 AM
Rear torsion rod bushings Infinityman51 Renault 19 0 01-07-2010 06:52 PM
Would you install bushings to a short shifter? amdsoldier Off-Topic 1 01-02-2004 02:23 PM
