Old 07-27-2003, 04:21 PM
djK1 djK1 is offline
how did they do that?
I have a 91 civic si hatch with the lame rear drums. So, how do you swap in some crx rear discs, I have some mechanical knowledge, (I have done the hybrid engine swap by myself) how hard is it to do? What parts do I need?
thanks,
djK1
p.s. what is the difference between the eye mount rear shock and fork rear shock and how do I know which one I have?
Si-leeper: "Take'm by suprise"
Old 07-27-2003, 04:36 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Here's a link for a rear disc swap how-to:
http://tjshondas.20m.com/rrdisc.htm
And another one:
http://www.fourthgenhatch.com/reardiscswap.html
Old 07-27-2003, 04:51 PM
88hondaowner 88hondaowner is offline
Banned
Send a message via MSN to 88hondaowner Send a message via Yahoo to 88hondaowner
I didnt know crx's came with stock disc brakes either??
Old 07-27-2003, 06:49 PM
GTA's Avatar
GTA GTA is offline
Whee..
only the 90-91 si's came with rear discs stock
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 07-27-2003, 07:04 PM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
90-93 integra rear disc setup can be used as well
There's nary an animal alive that can outrun a greased Scotsman!
Old 07-27-2003, 07:16 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
are discs really that much better? because atleast 70% of braking is done by the front brakes. Do people usually just do it to be different or for looks or something?
Old 07-27-2003, 07:24 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
i personally think its a waste of money, and that most people do it for looks because the drums look pretty gay, but if im gonna spend my money, its gonna be on going, and not stopping ... and i know you guys are all gonna say "well why go fast if you cant stop fast" but
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 07-27-2003, 07:35 PM
Well its not gay....but its also not very functional...
I definitely want to do it for cosmetic reasons, because drum brakes are just plain fugly on any car.
Old 07-27-2003, 07:58 PM
GTA's Avatar
GTA GTA is offline
Whee..
im probably going to do it cause my drums are shot and i have no ebrake currently cause of my drums being shot. So instead of buying new drums, shoes and possibly cylinders i'd rather jus tgo discs so they are easier to work on and look a lil better.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 07-27-2003, 09:21 PM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
yeah the only reason i would do the swap is for looks and the ease of changing pads versus shoes, plus nothing looks better behind a 17" wheel than a HUGE rotor with a MASSIVE caliper, and if you're gonna do a big brake kit on the front, you just GOTTA do it to the back, otherwise it just looks goofy... even if the front brakes do 90% of the braking...
Old 07-28-2003, 12:32 AM
91civicDXdude's Avatar
so hows that MPFI swap coming along
Old 07-28-2003, 01:34 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Brake bias is a factor, but you have to remember that drums aren't as efficient as disks. When wet, a drum will not operate as well as a disk (neither work that well anyway) and the caliper pressure from disks is a lot better than a single piston drum setup.
I find the disks on my SiR are better than the drum/disk combo on the Aussie GL. Then again, the front rotors are a lot bigger, as are the calipers.
What I do know is that most modern cars run disks all round - which tends to indicate that the manufacturers/designers know something
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 07-28-2003, 01:40 AM
blue4g2def blue4g2def is offline
Send a message via AIM to blue4g2def
Better rear brakes will probably allow more of the rear to do some braking which would reduce 'nose dive' when slowing down.
but yeah, who needs brakes, all they do is slow you down.
2000 Grand Prix GT: Did They Install a New Fuel Pump or Just Tell Me They Did? rhaltunen Grand Prix 6 12-05-2010 10:04 AM
