Old 07-27-2003, 12:52 PM
s10frameoff1993 s10frameoff1993 is offline
Send a message via AIM to s10frameoff1993
Transmission & Clutch
I have a 93 S-10 pickup with the 2.8L and 5 speed Borg Warner T-5 transmission. I just replaced the entire clutch system. Right now, the tranny is in neutral, push in the clutch and the truck starts fine. When I go to put it in gear, the truck moves forward. When I start the truck, and the clutch is down, and the shifter in gear, the truck hops forward. I made sure the clutch system is bled correctly and I definitely did that enough times. I took the access panel off the side of the transmission, pushed in the clutch, and noticed that the clutch rod only moves about 1/2 inch or so, that's it. I bled the system once again, but it made no difference. When I pushed the clutch fork in by hand, it seems that something is holding it from getting pushed in further. What I would like to know is: Does anyone have a detailed diagram of how the clutch fork, release bearing, drive plate, all get installed in the transmission? I'm worried that I installed something wrong or put the clutch plate in wrong or something. Does anyone know what could be the problem here? The transmission is new, the clutch is new, and the clutch system is new. Any help would be great. Thank you so much.
-Chris
~CS4LIFE~
www.csautoclub.com
Frame off on a 93 S-10 Pickup
Bagged & Layin' Frame
Chassis Is Molded And Painted
Suspension in ENTIRELY Chromed
Engine is Painted & Chromed
Polished Fuel Cell & Braided Lines
Stainless Steel Braided Brake Lines
"The more chrome the better"
Old 08-04-2003, 11:21 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
does your clutch have the diaphram type pressure plate or the spring type pressure plate? i don't thiink that the pilot bearing is moving, so you might not have gotton the release fork installed correctly. If you said that the fork is moving about a half an inch, that is plenty to release the clutch.
Old 06-24-2005, 04:24 AM
MrEleven MrEleven is offline
Send a message via AIM to MrEleven
Re: Transmission & Clutch
Did you replace the slave cylinder? did you replace the master cylinder? I would check those out first.
The man who paid for my truck
00 Eclipse GT (115k mi) Clutch Question Stock00ClipseGT Eclipse 2000+ 3 11-26-2010 02:39 PM
2005 Town & Country Transmission Problem kccohio Caravan | Voyager 1 09-06-2010 03:06 AM
Water VS Antifreeze & Clutch fan VS Non-Clutch PeteA216 Caprice 14 06-01-2007 12:14 AM
Gear Box & Clutch Pressure Plate Kit TONX Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 3 09-24-2003 12:14 PM
pressure plates & clutch discs H4Bangin '88 - '91 Civic | CRX | Wagon | Shuttlee 1 10-30-2002 06:15 PM
