Old 07-25-2003, 04:27 PM
CB91StangGT CB91StangGT is offline
Send a message via AIM to CB91StangGT
Ran codes, got code 29..... Help!
A little over a week ago when I had my converter installed, I noticed that my idle has gotton a little bouncy while in D. I reset the computer thinking that it was simply the car getting use to the new converter, but a week later it is still bouncy and is now stalling at times while idleing in D. Even though my check engine light was not coming on, I ran the codes and got code 11 (system pass) and code 29 (vehicle speed sensor; signal voltage is too low). Does anyone know what the vehicle speed sensor is and where it is located? I feel this is the problem.
1991 Mustang GT Conv: 60,000 original miles, 2nd owner :banana:
Built AOD w/2800rpm stall, 3.73's, aluminum d/s, 2 chamber Flowmasters, BBK shorties, 65mm tb, 73mm maf, subframe connectors.
1990 Mustang LX Conv 25th Anniv: 50,000 original miles, 2nd owner :banana:
2 chamber Flowmasters, o/r h-pipe, Pro 5.0 shifter.
Old 07-25-2003, 06:08 PM
94svt5.0's Avatar
94svt5.0 94svt5.0 is offline
iTs a plug-in on the left side of the trans tail, held on with a 10mm bolt. It has the speedo gear attached to it. At least that is on a t-5 not sure on an auto.
More photos and Info/website!
1994 Cobra
-off road h-pipe
-superchips power chips
-mac cold air induction
-BBK aluminum underdrive pullies
-pro-m 75mm bullet MAF
-18" konig wheels with nitto 555 zr tires
-Ford Racing 65mm throttlebody
-Ford Racing king cobra clutch
-Ford Racing 3:73 Gears
-Ford Racing Aluminum driveshaft
-Bullit suspension/ springs,shocks,struts
-Aubrun HD limited slip Diff.
2002 subaru Impreza RS
- stock
1989 Toyota pickup 4x4
-K&N
Old 07-26-2003, 12:01 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I had the same prob in my 87GT AOD when I changed Stall Convertors. My car has no VSS. I had to re-adjust my TPS.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 07-26-2003, 04:02 PM
I went to my local parts store this morning and picked up a new speed sensor for $25. When I pulled the old one out from the tranny the speedo gear was literally destroyed. It was missing half of its teeth. Luckily, I had a spare . So I put the gear on the new sensor, put it in the tranny and reset the computer. The car runs fine now. Idles perfect, doesn't stall, nothing. Been fine all day, I hope it last!!!
