Old 07-25-2003, 12:56 AM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
lug threads
when i was having my car towed to the car shop, i forgot to tighten the lug nuts and my wheel came off and messed up the inside of the wheel, the outside rim of the brake rotor, and messed up the threads of the lugs or whatever they are called. if i buy a new rotor, will it come with those, or do i need the bolts themselves?
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 07-25-2003, 01:00 AM
cyberfelon's Avatar
cyberfelon cyberfelon is offline
Send a message via AIM to cyberfelon
rotor wont come with em. your gonna need the studs themselves. FourthGenHatch has a good howto on his website of the process.
http://www.fourthgenhatch.com/wheelstud.html
Id rather be drifting...
Old 07-25-2003, 08:04 AM
Jay eS Iye's Avatar
so do i need to cut part of the stud itself off? looks easy enuf but i just didn't understand the cutting part.
Old 07-26-2003, 12:47 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Try sticking a new wheel stud in that hole, its not goin to fit because it can't clear the hub. You need that extra tiny bit of room you get to move it by cutting the side of it off.
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 07-26-2003, 09:50 AM
Jay eS Iye's Avatar
ok cool, i have my newest project, probably for this week, just gotta charge up the dremel and cutting the side odd womn't weeken it or anything will it?
Old 07-26-2003, 01:56 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
i haven't had any problems with my studs that are cut... try to not go overboard on it though...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 07-27-2003, 12:34 AM
Honestly that method isn't exactly as good as pulling the hub and doing it that way. But you still have like 80% of the seating area and everythign which is plenty, once they are seated they aren't going anywhere and they are probably equally as good as in whole from by that time. It's been many months and I've had no problems.
Old 07-27-2003, 12:59 AM
Jay eS Iye's Avatar
ok on hte how to he said he just cut off hte threaded part of the stud and knocked the rest out of the back, but i tried that and there just isn't enuf clearance, or so it appears. do i have to cut off hte head or anything? i've cut the ends off two so far, but it looks like there just isn't enuf room.
also, if i were to take the hub off, do i need to replace the bearings, or could i just regrease them and pound the studs in and out that way?
Old 07-27-2003, 10:37 AM
You need a hydrolic press to get the hub in and out of the knuckle. So thats why my way is easier. By cutting the threads that means use a Dremel or something and cut enough off the end of the stud so you can bang it out the back. You shouldn't even have to cut that much of it off.
lug pattern palmer6691 C/K 1 10-24-2009 10:27 PM
Lug nut cross threaded... Killa_CRX '88 - '91 Civic | CRX | Wagon | Shuttlee 3 05-13-2004 07:52 AM
lug nut thread size? sprucegoose Taurus | Taurus Wagon 0 03-15-2004 11:20 AM
